Sponsored by: Auxito
tranny fluid problem
Old Nov 16, 2010 | 10:16 PM
Moyerboy's Avatar
Moyerboy
Question tranny fluid problem
ok i dropped the pan on my 03 f150 and i changed filter blah blah blah well i over filled the tranny by lik .5 qt and it all the way to the top of the dont add mark, is there any way I can remove some of the fluid with out dropping the pan again?
thanks moyerboy
Old Nov 16, 2010 | 10:49 PM
ottawaguy's Avatar
ottawaguy
Though I've never tried it myself, I would find a tube or hose to fit down the filler tube and siphon/suck/pump it out!
Old Nov 16, 2010 | 11:21 PM
Bluegrass 7's Avatar
Bluegrass 7
The final level is set when the trans and fluid is up to operating temperature.
Fluid changes volume with temperature.
Old Nov 16, 2010 | 11:27 PM
ottawaguy's Avatar
ottawaguy
Does it not indicate that on the stick???
I'm sure it does...
*CHECK HOT*
Old Nov 16, 2010 | 11:29 PM
ottawaguy's Avatar
ottawaguy
Since the OP didn't ask how to check the transmission fluid level, I went on the assumption that he already knew how to do that.
Old Nov 17, 2010 | 09:01 PM
Moyerboy's Avatar
Moyerboy
well the dipstick tube does say add cold hot and dont add and fluid expands when it gets hot and i tried the suckin and its hard to get the hose down the tube but i got it out thanks.
dturnersr
Dec 25, 2018 03:01 AM
wildstang
Vermont Chapter
Jul 14, 2013 04:21 PM
bsquash
Testing.....
Jan 27, 2013 10:16 AM
Moyerboy
6.4L Power Stroke Diesel
19
Nov 1, 2007 01:03 PM
Fomoco_7
Oct 12, 2005 02:39 PM
