Both are good, both together are better. I have only added the Hellwig but I'm swapping out the rear springs for a set of (modded) B codes to address towing/load rear suspension issues instead of the RAS. I got the springs for free so it was an easy choice.
What is your application you are trying to fit with your Ex since that will help me with my advice.
In 'general' the RAS (and B code springs for that matter) will help with body roll over stock springs. Hellwig (i.e. a roll bar) is designed specifically for addressing body roll by tying the frame to the axle thru the spring bar...
The RAS adds the benefit of reduction of axle wrap as well as adding some spring capacity to offset any sag from heavy tongue weights like I carry (1100-1200#'s)...
RAS will also stiffen the ride some.
So each has a slight benefit over the other and it really depends on what you are trying to target specifically. If you do not tow...go with a Hellwig would be my advice. If you do tow a long and heavier trailer like I do...both are a great addition. If you only tow occasionally and only a small trailer...Hellwig would be great there too...it all depends on YOUR situation...sorry to not be concrete on my answer because it really does depend...sorry.
Let us know what you are attempting to correct body roll from...simply driving or towing.
Thanks to VR6Nutt here on the Forum, I will be adding RAS to my EX on Friday this week. The Hellwig I put on several months ago really helped with the Body Roll and tow handlign to some degree.
As X_Hemi_Guy says, I think both are the ticket (or modded B codes &
Hellwig) if you're towing heavy like I do. I really like the idea of some help wiht the axle wrap and the sag issue.
If you can find the B codes (free is always good) then that's a good mod. I just haven't been able to find them at a reaonable cost (new or used).
Thanks and WELCOME to FTE!
Joe.
Applications include a 9500 lb TT and occasionally a 5,000 lb boat trailer. Thank you!
Given the application of the heavy TT...I don't think you could go wrong with BOTH...I know my 9000-9100# TT sure likes both.
However if cost is an issue...I'd start with the RAS first and see how your setup handles it and then if you still feel there is more body roll than you like...add the Hellwig at that point. I recommend the RAS first due to the softer Ex stock springs and them needing some assistance to carry the tongue weight of your heavy TT which the RAS assists with.
Joe nailed it. With a 9500lb trailer, you will love the benefits of both. I have both the RAS and the Hellwig on my 2000 X 4x4, and pull an 8500lb 30' trailer. It does it beautifully. Never regretted it...
My '05 doesn't have a rear sway bar, so I'd be interested in
reducing the body roll.
Yes - do it immediately if you haven't already. Single greatest mod I've made on any car or truck I've ever owned. I'm amazed that Ford didn't install these on every Ex - the difference is night and day.
I had an '80 firebird (no rear sway bar from factory) when I added
a rear aftermarket sway bar it caused bad oversteer
(even with an upgraded front bar).
I've got a few things to do first (don't we always).
Great subject! Will the RAS and Hellwig help with the white knuckle sway issues?
I don't tow...but I just installed the RAS on my lifted 4x4..and it is wonderful. I just drove to the airport with the X loaded with family and luggage. I drove the winding highway down and across the golden gate..which has always been scary. This time it was easy and relaxing. My wife even noticed that I wasn't fighting the wheel keeping the X in it's lane. And the ride was smoother than ever. I have the stock rear springs on blocks.
