manual glow plug
Old Nov 16, 2010 | 10:35 AM
1bigjoe's Avatar
1bigjoe
manual glow plug
so ,i disconnected the wight wire off the controler, ran a new wire from that smaller post to a momentary switch in the cab, then a ground wire from the other side of the switch to a good ground -------nothing
no power to the plugs and all those zd9's are good.
and when i put atest light to the small post. the light comes on says it has constant power --wtf 1990 7.3
Old Nov 16, 2010 | 01:40 PM
1bigjoe's Avatar
1bigjoe
i guess i should have asked the questions
a. what did i do wrong
b. what do i do to correct the problem
thank you in advance
Old Nov 16, 2010 | 04:30 PM
Lukes66's Avatar
Lukes66
I had to run hot to the momentary switch and then to the GP solenoid. My solenoid was 12v activated not ground activated, but my truck is an 85.
Other than that, I would check for continuity between where the GP harness connects from the solenoid to the GP connectors themselves.
Old Nov 16, 2010 | 05:13 PM
1bigjoe's Avatar
1bigjoe
tommoro is an other day, just gets to dark to soon, i think i'm going to try giveing power to the plugs, instead of grounding the white wire post
maybe some one will have the ans.
Old Nov 17, 2010 | 12:03 PM
ttexastim's Avatar
ttexastim
Try testing it right there at the battery/solenoid. Take a ground wire and touch it to the solenoid enable post and make sure you hear a click. If so, then just make sure you wire your switch between ground and that post.
I'm not familiar with your year, because, like Luke, mine is activated off 12 V.
Old Nov 17, 2010 | 12:40 PM
1bigjoe's Avatar
1bigjoe
ok, so here is what i did ..
took the selnoid off put on one i had from junkyd
went back to removing the white wire , re ran wire to moment swtch
other end to ground ---and presto ----it is alive!!!!!
Bill's2000X
Jul 16, 2014 05:51 AM
Eallend7
Dec 23, 2012 09:28 PM
xccoach4ever
Nov 2, 2012 07:22 AM
voodoosurfer
Nov 3, 2003 10:50 PM
