sprung a leak
Old Nov 16, 2010 | 09:47 AM
stephen.osborne1's Avatar
stephen.osborne1
sprung a leak
A couple weeks ago my wife noticed water pooling on the driver's side floormat, so we took it in and they replaced the seal on the roof of the cab- problem fixed. Then the other day she noticed a few drops coming from the Oh $#it handle on the passenger side. Not as bad a leak, but still, there is an airbag in the A-pillar and that is where the water is coming from. Gotta take the truck back in tonight and leave it... Hope they don't give me another crappy Ranger as a loaner.
Old Nov 17, 2010 | 08:00 PM
stephen.osborne1
As it turns out, the Sirius antenna was the culprit this time. Not a major leak and easy fix.
Old Nov 17, 2010 | 09:58 PM
Jr.Ranger's Avatar
Jr.Ranger
The amount of rain we have had the last couple of days will find any leaks u may have hope u got them all??
Old Nov 17, 2010 | 10:10 PM
Matts72's Avatar
Matts72
That Sirius antenna is fun in the middle of a car wash with water streaming into the cabin!
Old Nov 18, 2010 | 05:54 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Sure seems like these trucks might be quite prone to leaks... My buddy's '09 regular cab leaked at the 3rd brake light and messed up his headliner. They replaced the headliner and everything and it is fixed now. Glad yours is leak free again.
Old Nov 18, 2010 | 06:33 PM
efx4's Avatar
efx4
We had a Pontiac G5 in work the other day with water leaks on both sides of the rear headliner. We lowered it and saw that the 2 drain lines for the sunroof had clogged and came off, causing water to travel to the rear corners. So if anyone has a sunroof, keep the drains clean or the bad weather can invite itself in un- invited.
Old Nov 20, 2010 | 07:36 PM
ohboy44's Avatar
ohboy44
I believe our trucks where built around the same time if I remember correctly.
There is a TSB for the satelite antenna leaking, if it's built before mid Jan. 2010.
Tparkin99
13
Jan 29, 2017 02:35 AM
gman97005
Jan 24, 2016 07:04 PM
trevorrules
Nov 6, 2015 01:08 PM
1L243
65
Feb 26, 2013 10:24 AM
marks500
20
Nov 25, 2011 08:03 AM
