A/C Vacuum Control
Old Nov 15, 2010 | 10:35 PM
tlane's Avatar
tlane
A/C Vacuum Control
I need an in-dash vacuum control for the bi-level function for my F-100. The dash and a/c components are from a 1978 F-100. Have tried LMR and National Parts Depot. No luck. Thanks for any leads.
Old Nov 16, 2010 | 06:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Look at the two following illustrations. In the first picture, is the part you're talking about basic p/n 18502 or19B888? If not, what part or you talking about.
Let me know the basic p/n and I'll see if I can locate it.
Click on the .pdf link to view the illustrations.
File Type: pdf
File Type: pdf
Old Nov 16, 2010 | 07:59 PM
tlane's Avatar
tlane
A/C Vacuum Control for '78 F100
I think its the 18A318. I will get the broken part from the mechanic tomorrow and email you back.
Thanks.
Old Nov 16, 2010 | 09:28 PM
mikeo0o0o0's Avatar
mikeo0o0o0
There are three different 18A318 vacuum motors, depending on the function code listed in the diagram.
Motor assy, vacuum control.
Function 1 or 2 D7TZ-18A318-A
Function 6 D3TZ-18A318-A
Function 7 D3TZ-18A318-B
I couldn't locate any of the first p/n
1 of the second, NOS Parts Source (913) 220-5746
1 of the third, Antique Auto Arlington (817) 275-2381
Old Nov 17, 2010 | 06:57 AM
Ronzi's Avatar
Ronzi
Dennis Carpenter has a few of them in thier catalog.
Old Nov 18, 2010 | 02:12 PM
tlane's Avatar
tlane
Thanks. I spoke with the Dennis Carpenter folk; I may have had an incorrect part number as they said they did not have it. I hope to retrieve the old one from the mechanic so I can get an accurate picture and part number. It's the vacuum actuator for the 'hi/lo' heater-ac control. There are 3 vacuum actuators behind the dash and apparently they are all different.
Thanks again.
Old Oct 11, 2023 | 05:53 PM
Wallys f100's Avatar
Wallys f100
1st Gear
I need one! Vacuum control valve D5TZ-19B888-A
I am in need of a vacuum control valve 76F100 Air-Conditioning heating valve for the dash the lower slide arm on the dash
Old Oct 11, 2023 | 09:38 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Lower slide arm is the bigger switch of the 2. How many vacuum ports does your have, 8 or 9 ? And how man blades/fins on the elec connector 2 or 3? I might have one left in my parts shed. I can look this weekend.
FTE safe seller. https://www.ford-trucks.com/forums/forum238/
