Hello people,,got a ?
Old Nov 15, 2010 | 07:52 PM
great white whaler's Avatar
great white whaler
thanks guys
Old Nov 15, 2010 | 08:03 PM
great white whaler
Originally Posted by Hitokori
well... 97 f250 with a 4.6 and a 4spd...
sounds like u blew the intake manifold gasket... that would whistle... and prolly backfire... best bet would be to scan the codes
got no scanner 'no lite in the dash changed the bulb still don,t work......i don't here a whistle when its idling in da drive way' any ideas thanks guys
Old Nov 15, 2010 | 08:10 PM
Hitokori's Avatar
Hitokori
my 302 has a whistle but its caused by the butterflys in the TB... missfire could be a dead plug or a dead wire... maybe a coil... could even be a spark plug tip mashed flat...
Old Nov 15, 2010 | 09:29 PM
hansol04's Avatar
hansol04
I think the johnson rods are worn. I would get a Chiltons and browse for johnson rod repairs, under the "engine" section. The whistling is a dead giveaway.
Old Nov 15, 2010 | 09:48 PM
Kapusta's Avatar
Kapusta
If you're wondering, a johnson rod is a device that is connected to a gazach via a knibbling pin. Probably what happened was the johnson rod fell from the gazach because the knibbling pin fell out.
It looks something like this...
Old Nov 15, 2010 | 09:58 PM
raystankewitz's Avatar
raystankewitz
My opinion . . .
I doubt it was the Johnson Rod. He said nothing about having no second gear in reverse.
Most likely the overdrive poppet under the transmogrifier valve ran out of lube. That's why I'm not fond of the Mod Motors.
That and the left handed threads on the spark plug boots.
Ray
Old Nov 16, 2010 | 03:10 AM
great white whaler
Ray
what kinda drugs ya usin boz must be good stuff
Old Nov 16, 2010 | 11:16 AM
Kapusta's Avatar
Kapusta
Ray
Old Nov 16, 2010 | 12:21 PM
great white whaler
Thumbs up
pulled the intake was leaking new gaskets' EGR was plugged ' replaced injecter o rings' spark plugs 'and wires she purrrrrrrrrrrrrrrrrrrrs like a kittin and lots of power,,,,,,,,,,
Old Nov 16, 2010 | 12:32 PM
Duct Tape Racing's Avatar
Duct Tape Racing
Sounds like a bad muffler bearing. There fairly cheap, you can find it here Muffler Bearing - $49.99 : KaleCoAuto, Hard to find automotive items!
Old Nov 16, 2010 | 12:35 PM
6CylBill's Avatar
6CylBill
Originally Posted by lew52
...Im with Bill on this one , he just spelled it wrong , its fartanoidater fluid....Lew
rofl hahahahaha!
badbrains
New Member Introductions
Apr 4, 2013 03:17 PM
DaytonaTunnel
Jan 16, 2011 11:12 AM
gthbryce
May 21, 2009 08:47 PM
danshula
Feb 3, 2007 09:19 AM
6ltrMike
Minnesota Chapter
Jan 30, 2005 10:16 PM
