intercooler parts
Old Nov 15, 2010 | 01:00 PM
redman84's Avatar
redman84
intercooler parts
I know we can use an IC from a 7.3 or 6.0 but how about the pipes? Not the spider but the hot/cold side ic pipes. I've found one at work with pipes but I don't know what year or if the pipes are even different between the years.
Old Nov 15, 2010 | 01:07 PM
ccarrier's Avatar
ccarrier
99-03 7.3 will work
Old Nov 15, 2010 | 01:08 PM
427 fordman's Avatar
427 fordman
Originally Posted by ccarrier
99-03 7.3 will work
With some modding..lengthening mainly
Old Nov 15, 2010 | 03:13 PM
Brown Falcon's Avatar
Brown Falcon
The 6.0 pipes can work too. Jose used them on his.
Old Nov 15, 2010 | 05:14 PM
redman84's Avatar
redman84
So how can I tell the difference? There's a huge salvage room and the ic and the pipes are just laying around
Old Nov 15, 2010 | 05:39 PM
427 fordman
I don't know, suppose you'd need some pics to look at. I know some of the 7.3 pipes are aluminum so take a magnet with you to tell them apart. When I did mine the guy had a big pile of pipes to choose from and I took 3, one for each side and one to use as extra for modding when necessary. When I went to weld together, found out one of the 3 was aluminum so I had to get a boot to put it together.
I'm not sure how to tell the difference b/w the 7.3 and 6.0 pipes. I'm sure there are pics somewhere but I'm not one who knows where.
Old Nov 15, 2010 | 05:43 PM
plgebbia's Avatar
plgebbia
Here is what 7.3L pipes look like:
Old Nov 16, 2010 | 07:55 AM
tbone heller's Avatar
tbone heller
I bought all of my pipes, boots, & clamps here: Aluminum Pipes
Old Nov 16, 2010 | 03:08 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Look this links, could be help for you.
http://outdoors.webshots.com/photo/2407247500099659029xhzXOQ
http://www.doitrightinjection.com/
And I attached a couple of pics of the pipes I bought with the IC and I used one as it was for the drivers side (the closest to the IC) and the distal part of the other and added a angle (45 grades) pipe for the pass. side with a boot between them and then with large boots to the Y pipe.
Old Nov 16, 2010 | 11:41 PM
oldbird1965's Avatar
oldbird1965
I just did a hack job by putting a piece of exhaust pipe (2") inbetween the spider and the 99 intercooler pipes, then double booted it. don't laugh!
JohnDeereFarmerUSMC
Oct 22, 2012 07:02 PM
snakedoc
19
Jan 26, 2012 02:02 PM
69Cobra
May 26, 2010 08:07 PM
patrickke
Mar 31, 2010 03:47 PM
bigsteve1969
19
Nov 27, 2009 12:27 PM
