E4OD Temp sensor
Old Nov 15, 2010 | 11:16 AM
Five-O's Avatar
Five-O
E4OD Temp sensor
I'd like to hook up a inline temp gauge sensor at the front fluid exit point on my trans, E4OD. I know B&M has a kit that splits the line but I would rather have it between the trans case and the line out fitting so I don't have to cut the line. Anyone knows who sells such a kit or fitting assembly?
Second question why does B7M want you to hook it up on the return line? that would not show spikes while climbing hills ect as well.
Old Nov 15, 2010 | 10:27 PM
86F150302's Avatar
86F150302
This is where everyone with E4ODs connect the trans temp sensor.
Screws right in.
Old Nov 15, 2010 | 10:36 PM
Five-O's Avatar
Five-O
Yes but the problem with that location is it gives a general reading and does not give a accurate "real time" reading , meaning that location gives the similar reading as hooking it into the pan and will be slow to show heat spikes you get when pulling a trailer up hills ect.
The exit out fluid line will show true hot temp
94BigGulp
21
Dec 9, 2014 08:37 AM
Thor'sHammer
May 19, 2014 01:37 AM
shuttlevalve
Jun 16, 2010 06:35 PM
jimjoebob99
17
May 13, 2010 06:43 AM
