6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Disappointing fuel mileage
Old Nov 14, 2010 | 11:00 AM
mike_pop's Avatar
mike_pop
I just got my SD a couple weeks ago. I wish I knew how crappy the 6.4 was on fuel before I bought it. I would have looked for a 7.3 or 6.0. I've had larger diesel trucks get better mileage than this POS. I've got friends with the 7.3 that get over 23mpg on the highway.
I do like the truck, how it drives and feels. But when I traded in my V10 Excursion that got 13mpg around town and 15mpg on the highway, I thought that a diesel truck would do at least that if not better. My '08 SD is only getting 9-12mpg around town and I haven't had a chance to check the highway since I added a Superchips yesterday. (I didn't have to remove the DPF since the previous owner gutted it.) My Excursion got 8-10mpg pulling a trailer and when I pulled a trailer with the 08, I got 8-9mpg. I did change out the EGR which has helped but not by much.
I'm very disappointed and am already looking to get rid of this truck for an older model.
Thanks for letting me vent. :-)
Old Nov 14, 2010 | 11:15 AM
longview1's Avatar
longview1
Banned
Sorry to hear youre so disapointed. I think the mileage is the biggest complaint with the 6.4.
I was well aware of the crappy mileage before I bought my 08', But the truck around it is just so much better than the 7.3/6.0 trucks. Well worth it in my books. I plan to do everything possible to help with mpg's though.
Old Nov 14, 2010 | 11:18 AM
mike_pop's Avatar
mike_pop
What kind of mileage are you getting Longview1?
Old Nov 14, 2010 | 11:38 AM
nomorecummins's Avatar
nomorecummins
Did you buy it from a dealer with the DPF gutted?
Old Nov 14, 2010 | 11:41 AM
longview1's Avatar
longview1
Banned
To be honest I havent hand calc it yet.
I picked up truck in Vancouver and drove home, about 1300kms. The truck said I was getting 13/14 liter/100km which equals ~17mpg. (which sounds about right, maybe a bit high as Ive done the drive numerous times in the corvette which has fuel tank exactly half the size and could get 30+mpgs on highway. Could go about the same distance as truck before fueling up, so the truck having 2x fuel tank gets half the mpg the car gets.)
Around town so far Im getting about 17/18 litres/100km which equals ~about 13mpg, I think might be a bit high as well.
I will be driving back down south at end of the month towing an enclosed trailer with car in it, and bringing back all my and my gf's stuff, I will hand calc when I leave here for better idea.
Old Nov 14, 2010 | 12:23 PM
cartmanea's Avatar
cartmanea
What is turning the regens off if the DPF is gutted?
Old Nov 14, 2010 | 12:27 PM
nomorecummins
[quote=cartmanea;9557423]What is turning the regens off if the DPF is gutted?[/quote
Superchips, but from what I can tell he has been running it tuner free with the DPF gone until yesterday.
Old Nov 14, 2010 | 12:35 PM
cartmanea's Avatar
cartmanea
You can't run them without DPF with no tuner to turn the regens off. Sounds fishy...
Old Nov 14, 2010 | 12:40 PM
nomorecummins
How long have you had the truck? You posted you just added superchips yesterday, which means you have been running it tunerless until yesterday correct?
Old Nov 14, 2010 | 02:39 PM
sdetweil's Avatar
sdetweil
I get 12.5 empty non-highway, and about 14 highway empty
and about 9mpg towing 7000lb flat front enclosed car hauler. on the vehicle in my sig
Sam
Old Nov 14, 2010 | 02:53 PM
mike_pop's Avatar
mike_pop
I bought the truck from the dealer with a gutted DPF. They didn't want to spend the money on replacing it so I took it as is, knowing I could tune it. I'm guessing that the previous owner gutted it but never tuned it.
I ran the Superchips program and drove the truck around town today. My Lie-O-Meter is reading 17mpg which is a substantial difference before tuning. I won't know if it's accurate until I hand calculate.
Old Nov 14, 2010 | 03:22 PM
cartmanea's Avatar
cartmanea
Its illegal for a dealership to sell a vehicle without required emissions equipment.
Old Nov 14, 2010 | 03:38 PM
nomorecummins
Wow, I can't believe your truck didn't go into limp mode without a tuner on it. You should see a 3-4 mpg increase with your tuner hopefully.
Cartmanea is right, its illegal for dealerships to sell you a modified truck. They have no problem voiding warranties on peoples, but if your trading in the truck they have no problem selling a modified truck to a customer. So in turn, I have no problem having FORD pick up the tab even if my tuner cases a failure....
Also, you have the ball in your field now. If I was you, I would go back to the dealership and tell them that if they don't fix it or give you another truck you will go straight to the Attorney General.
Old Nov 14, 2010 | 04:02 PM
mike_pop's Avatar
mike_pop
nomorecummins & cartmanea:
I bought the truck knowing that the DPF was gutted. The dealer was going to wholesale the truck but I told them I would accept the liability. So, if you are trying to find some sort of suit for reparation for me, look elsewhere. The issue is not what the dealer did or did not do. The issue is the crappy fuel mileage and steps to correct it.
Also, before tuning, the regen was still cycling and the DTC code was coming on. After tuning, no regen, no codes, and hopefully better mileage.
Old Nov 14, 2010 | 04:21 PM
nomorecummins
We are just trying to help, but it seems you know it all so good luck.
