Fuel Smell
Old Nov 13, 2010 | 09:07 PM
trout bum's Avatar
trout bum
Fuel Smell
My early '99 was stolen and totaled recently and I replaced it with on '02 7.3L. I've been noticing a fuel smell and today I found a small puddle of fuel in the valley. Could this be just a fuel filter leak or something more serious?
Old Nov 13, 2010 | 09:15 PM
schlepprock250's Avatar
schlepprock250
Common problem,it's probably the o-rings for the drain valve on the back of the fuel bowl,also double check the fuel filter cap and make sure it's tight.
Old Nov 13, 2010 | 09:47 PM
eetalt's Avatar
eetalt
From what I've heard around here, it is likely to be either an HPOP O-ring or a leaky filter bowl. Both are relatively easy to fix with well-organized/packaged parts from dieselorings.com. Others will likely chime in with more familiarity about procedures. Good luck!
Old Nov 13, 2010 | 09:51 PM
BillyBob69's Avatar
BillyBob69
Contact Diesel O-rings for the fuel bowl drain valve o-rings. Cost about $3 and takes about a half hour to change out. If you do a search on here for o-rings, you will find his threads and contact info. Easy fix.
EDIT: Here is his web site http://www.dieselorings.com
Last edited by BillyBob69; Nov 13, 2010 at 09:52 PM. Reason: Here is his web site: http://www.dieselorings.com
Old Nov 17, 2010 | 09:16 PM
trout bum's Avatar
trout bum
Thanks guys. This is why I love this site so much. I have learned a lot about these trucks on here and I have only scratched the surface. I'm thankful that there are so many knowledgable folks here that are willing to share what they know.
