Project Steel Dreams 1950 F2 build
#167
As promised, here is the latest. I went up to the shop fairly early this am because I had a lot to do. First thing was to jack up the truck and take the front wheels off. They went into the back of my truck to go get the new rims mounted this next week. A bit of good luck, I found a set of mag shank lug nuts and washers and they fit perfectly. I know the thread is ok because they came off my truck with the original tires. Just have to buy new washers as these are chewed up and for the little money it is worth it.
Next was figuring out how to mount the new cooler which looks like this.
After a fair amount of time trying to get this to fit and work I finally came up with a way to mount the cooler directly in front of the radiator fan. So if it is hot enough the fan will pull air past it. So I made some brackets which is a lot easier to say than do.
Not fancy but effective. BTW: I should have saved and taken a picture of the collection of electrical tape, wire and string that was used to hold up the trans lines.
I will finish this install when I go back up as the brackets were still not dry from the painting.
I also installed the electric speedo signal generator. Pretty neat deal.
For whatever the reason this has been a long and difficult day. Everything just took it to the max. Oh well you have got to expect these things to happen. Next time will be better as I should be taking the new tires and rims up with me to mount on the truck. And that means PICTURES !!!
jim
jim
#169
Well it was in the low 80s today and I couldn't resist going up to the shop where the truck is. I added a couple of coats of paint to the mounting brackets and some on the frame rails under the cab. Flat black anti-rust paint.
However the best part was this.
Small but important to me. Now I get to answer the "What is an F2 ?' questions.
jim
jim
#170
jim
jim
#171
You know for a trucker you are pretty sharp... That is exactly what we were working on. Had to figure out the right size and placement while still remembering it could have been painted in 1950. Of course the original design got changed around so I have to re-make it. The hardest part is getting a stick on stencil made. Hell I don't even know what it costs but I will.
jim
jim
#172
#173
#174
#177
#178
Hi.
You just know when you are having a good day, it just feels really good. Today I had that kind of day. It started with my ability to be able to get up to meet the day. Today I hit the magic number, 65. That means I am offically old.
Well here is what the old guy did today. The first thing I did was assemble the mounting brackets and the cooler. TWICE Yeah well I knew eventually I would get it right.
I got the cooler installed so here is a picture to give you an idea of how and where it fits. I set it that way so when the fan kicks on it will also pull air over the trans cooler. Well that is the plan.
Once I cleared out the mess the po had left I cut down the tubes so they were close to the same length. By doing that I was able to support the hoses so they didn't rub on anything.
More pictures here:
Shop Pictures pictures by hellfirejim - Photobucket
As good as that felt the next part was even neater. I got to mount the tires and the new front rims. I let it down on the ground and just looked at it. Then I smiled.... I like it!!!
I picked this picture for a reason. Look at the front of the truck at the bottom of the valence and that my friends is a 2 x 4 on it's side and there is still some room left. Not much Only sheet metal down there and nothing to hurt.
Beyond the fact that I think it just looks cool, it is now drivable. I will be able to drive it in a relaxed mode because I don't have to worry about hitting the front end. All I did was change the tire situation and it all fell into place. It is good to be lucky.
Here is a link to the rest of the pictures.
jim
More pictures here:
jim
#179
#180
