no heat
Old Nov 13, 2010 | 05:00 PM
BIG ATS's Avatar
BIG ATS
no heat
ok here it is i have a 2000 ford excursion w a v10 4x4. I need help bad due to it getting realy cold here , i changed the therosat on my truck and now i have no heat, before i had a liltte heat before i change it, i got the therosat from car quest 195 dergree i took a temp to the housing i get 150 i thought that i had a faulty therosat so i went got a onther one and its doing the same thing i dont under stand it so please help me i would be greatly in debt to who help its cold here with three kids so please help me
Old Nov 13, 2010 | 09:07 PM
CrzHelm's Avatar
CrzHelm
your problem may be in your air ducts or climate controls. the blend doors can be staying open, could possibly be the actuator. look behind your glove box. see if its hot
Old Nov 13, 2010 | 09:19 PM
FordMstrTech's Avatar
FordMstrTech
Be sure your cooling system is full. Take a temp reading at your heater hoses, u will see 2, one going into the heater core and one coming out. There should be atleast a 30 degree difference or so. Post up what you find and we will go from there...
Old Nov 13, 2010 | 09:21 PM
tdappleman's Avatar
tdappleman
Make sure the vacuum valve to the heater core is opening as well.
Old Nov 14, 2010 | 11:22 AM
bgalaxy67's Avatar
bgalaxy67
Look to see if your heater control valve is working. Mine looked like it was working but when I pulled it, it was gunked up.
kevbits
Mar 1, 2015 05:20 PM
sammie0126
1997 - 2003 F150
16
Sep 26, 2014 11:59 AM
aintskeered
1997 - 2003 F150
18
Dec 19, 2011 07:16 AM
Lookeee
Nov 13, 2011 05:28 PM
koboss1
6.4L Power Stroke Diesel
29
Feb 3, 2010 10:12 AM
