76 hiboy tear down resto mod build thread
#32
#36
#37
If it only came out as far as it did in xxx thousand miles then it shouldn't move with the block peened around it.
#39
heading int he right direction....i think.... lol
well i have been fooling with it when i can during the week, but the cold weather really dosnt motivate me much. last weekend i swapped the adapter plates and pulled off the automatic dodge tranny cooler thing, wont be needing those.
old stuff
new adapter
also pulled off the AC compressor which was tougher then anticipated. luckily i didnt need it because it is now destroyed. the 2 upper bolts came out just fine. the lower 2 had mega dissimilar metal corrosion between the ac compressor and bolts. the heads broke off with the impact so i had to grind a slot in the bottom along the bolt and crack it to pieces to get it off. it did not wana give up. oh well, more for the scrap yard! lol.
whats left
my stupid oil pan bolts finally came along with the gasket and pick up tube. my engine didnt come with any of that or the pan its self so i finally collected it all and got it put on so i could try and stick it in place and find out how much i need to notch out the cross member.
old stuff
new adapter
whats left
#42
I am glad to see I am nto the only person who is into swao =D I am swapping a 7.3 into a 75 Hi Boy, but I have stopped that project to do up a 78 F100 with a 460 and a 4 spd top loader. But if I can be of any help just PM me, I have a ton of info ont eh trucks and some knowledge of what some other people have done to make diesel swaps SUPER easy.
#43
#45
My two cents: I did the steering gear swap on my 76 Hiboy and believe me, it is well worth it. It drives like a completely new truck now. And yes a gear from a 2 wd will work but it just sits a lot taller in the engine bay, with your steering shaft sitting (I think) almost horizontal.
im not sure who actually makes it weather it be ford or cummins but it came off a 4bt out of a delivery truck. ford used the 4bt in some of their old step vans and this adapter fits the zf
