76 hiboy tear down resto mod build thread
#152
impalaslayer the only thing I thought you needed to do was attach that plate to the frame in a couple more places, preferably as close to the studs as possible. And frankly, the weld on that most critical component isn't your best.
The other guys frame is likely to crack or break where his fabbed stuff meets the original frame.
Stress risers are a moving target.
#153
#154
im redoing it one way or another. weather i will go through the plate and the frame with spacers like my bronco is or re weld it the way i have it with a bigger welder is yet to be determined. i think i like the first option better but will take more work. but im not really worried about that so i like the first option more and more.
#155
#157
#158
But somehow I'm finding wisdom in each of those posts. I'm praying the streak continues.
#159
on a roll? you must have seen my post complaining about a for sale add here. Just bugs me when people do that. They seem to be slipping through a bunch recently. I know admin asks that classifieds stick to that forum so I do so with mine although I'm sure I'd get a bunch more sales if I were to post here as 99% of my stuff is for these dentside trucks and not everybody makes it down to the classifieds to look.
As for being helpful - I'd like to think the majority of my posts are. I linked a bunch of stuff for a guy asking about seat installs. Including my build thread on the matter which had TONS of pics. I could have told him "do a search - it's been covered" but I was nice
Ok - now we are getting off track again...
Impalaslayer - have you started redoing the steering box mount yet?
#160
#164
I would make sure that the box will clear. I'm in the process of mocking up my steering box (same 79 box as yours) with my cummins sitting in the truck and it is quite tight. I have my cummins offset 1" to the passenger side and the steering box is awefull close to interfeering with the vaccum pump diaphram. i've actually notched the top web of the frame to allow me to mount the box further to the passenger side. I'm going with a similar mounting plate, mines 1/2" thick plate with 1/2-13 treaded holes, then i plan on welding nuts to the back side. i'm also planning on dropping the steering box down a 1" or so into the frame. good luck and good looking build!! keep up the good work.
#165
