Spring Shackle; CDR
Old Nov 23, 2010 | 06:11 PM
catfish101's Avatar
catfish101
Oreo, Both ends on the front are rigid?
Old Nov 23, 2010 | 08:11 PM
oreocreaming's Avatar
oreocreaming
no, front rigid, rear is shackle.
Old Nov 23, 2010 | 08:14 PM
oreocreaming
Originally Posted by The_Josh_Bear
Ok so I've found some Add-a-Leafs for around $110 shipped and I'm ready to pull the trigger, but:
I've read a bunch about them making the ride suck, which isn't the hugest deal to me(it's a TRUCK for goodness sake) but is it really that bad? if it takes it back to the original height(ish) then it should still drive similarly, right?
Also, the PO installed adjustible ball joint bushings, which are already maxxed out, so those should be very helpful in re-tuning the camber after the lift, score for me.
I have probably only 3/4" between bumper and stop on my suspension, maybe 1". What's "normal"?
Thanks!
it wont make your ride that bad. 1 leaf is alright, brings the height back and helps carry the weight of that heavy *** idi. yea, will drive good as new. you should have more travel then that. your springs are sagging pretty good.
Old Nov 23, 2010 | 08:19 PM
catfish101's Avatar
catfish101
ok I didn't see the rear pin on the front spring.
Old Nov 24, 2010 | 01:14 AM
The_Josh_Bear's Avatar
The_Josh_Bear
Sweet! Thanks a lot, Oreo! I'll order it up and post the results.
Old Mar 18, 2011 | 09:56 AM
The_Josh_Bear
Sorry it's been so long with my add-a-leaf update, I have had them on my truck for 3.5 months now and I am VERY happy with them!
The ride is what I would imagine stock to feel like, maybe with a touch stiffer spring rate, which is fine by me. But it's better in all ways.
Thank you Oreo for being the only guy on the internet(it seems) that knew about the ride quality of this install. Everyone was assuming they would stiffen it up way too much.
My only gripe is that they didn't bring it back perfectly to camber, still a touch low, and the PO didn't actually have adjustible camber bushings installed so I lost out on that. But my stock springs had a one-spring-thickness shim on them which I can install under the whole thing that may just bring me out to where I need to be.
Thanks all and by the way off-roading is WAY more fun when you have suspension travel! haha
-Joshua
Old Mar 18, 2011 | 10:04 AM
The_Josh_Bear
-Joshua
Scott51
Nov 14, 2016 09:15 AM
LipschitzWrath
17
Apr 7, 2015 07:08 PM
Twilight Fenrir
Nov 5, 2013 05:21 AM
OldWoodsDiesel
Oct 22, 2012 07:45 AM
gearhead351
Offroad & 4x4
46
May 15, 2009 09:24 PM
