Tightening shackle and leaf spring nuts and bolts
Im in the middle of replacing my rear spring mount and I am about to start putting this thing back together. Is there any specified torque or process in tightening the large nuts and bolts on the leaf springs and shackles? Should I leave them loose and tighten them up once the truck is on the ground and the suspension is loaded?
thanks!
Jeff
thanks!
Jeff
Not a good idea. It should of had the weight on it so it will not bind. lock washed are not a good idea either, should of used lock nuts
I just hit them with the gun till I knew they were good and tight.
Yup that'd be me, as brad pointed out no need to actually torque them unless you want to and yea do it with the tires on the ground and suspension loaded.
I wouldn't use extra hardware like lock washers especially where I live, not up to the task and tend to rust away fairly fast leaving the fastener loose, where the self locking nut wouldn't be effected.
JeffNJF150
17
07-21-2013 04:21 PM
stangclassic66
08-13-2008 03:14 PM
