injecter problem
Old Nov 13, 2010 | 06:14 AM
ralph54's Avatar
ralph54
injecter problem
i have 1992 f150 5.0 i have had problem with with missing under load and low rpms checked and replaced a lot of things finnally discovered if it is running you can pull connecter off no.8 cyclender injecter it will smooth out and run good as long asyou don`t switch it off but if you do it starts missing again replaced fuel injecter does the same thingas before the only code is 172any one else had aproblem like this imeant unplug and plug back up.injecter
Old Nov 14, 2010 | 07:31 AM
ralph54's Avatar
ralph54
can anyone help thanks
Old Nov 14, 2010 | 08:59 AM
subford's Avatar
subford
Sounds more like a spark plug wire or plug problem.
Check the voltage on the spark plug wires with it running.
See if one wire is a lot higher KV then the rest.
Old Nov 15, 2010 | 06:59 AM
ralph54's Avatar
ralph54
it has new wires plugs roror cap and coil.
Old Nov 15, 2010 | 08:09 AM
subford's Avatar
subford
I put new wires, plugs, rotor & cap on my F53 and started out on a trip and about 100 mi into the trip it started doing the same thing. After putting my KV meter on it #7 voltage was too high.
The plug wire was not all the way on and after closing the end some and putting it back on the the voltage was down to normal and no more miss under load.
Old Nov 15, 2010 | 08:46 AM
ralph54's Avatar
ralph54
thanks how do you check voltage and what should it be
Old Nov 15, 2010 | 09:35 AM
subford's Avatar
subford
I use one of these to check the voltage.
As long as the dial has about the same number at each plug wire when checked at the Distributor Cap I call that wire OK. If one is higher then the rest or lower I know I have a problem with that plug, wire or cap position.
My HV tester:
