horsepower
Old Nov 12, 2010 | 08:57 PM
low 66's Avatar
low 66
horsepower
Any ideas of how much horsepower my 352 in my 1966 f100 might have
Old Nov 12, 2010 | 09:01 PM
Bear 45/70's Avatar
Bear 45/70
352 4 barrel was rated at 250 hp @ 4400 and 352 ft/lbs @ 2800. That was with a 9.3 to 1 compression ratio.
Old Nov 12, 2010 | 09:11 PM
low 66's Avatar
low 66
Why does that not seem like alot of h.p. coming out of a big block very puzzling to me
Old Nov 12, 2010 | 09:28 PM
Bear 45/70's Avatar
Bear 45/70
It is a very little big block at 352 CID.
Old Nov 12, 2010 | 09:35 PM
low 66's Avatar
low 66
Yeah I guess u r write but I would have thought that it would have more horses then that
Old Nov 12, 2010 | 09:58 PM
Bear 45/70's Avatar
Bear 45/70
There were only 2 352 engine with more horsepower than that engine.
1958-60 352 4 barrel, 300 hp @ 4000 & 380 ft/lbs @ 2800 with 10.2 to 1 compression
and
the 1960 352 H.P. 4 barrel, 360 hp@ 6000 & 380 ft/lbs @ 3400 with 10.6 to 1 compression and a mechanic cam.
Old Nov 12, 2010 | 10:07 PM
low 66's Avatar
low 66
How would I know if I have either of them
Old Nov 12, 2010 | 10:12 PM
Bear 45/70's Avatar
Bear 45/70
Did your truck originally come with a 352? Then it wasn't one of those engines as they were available only in 1958, 1959 and 1960. These engines were only available in cars also.
Old Nov 12, 2010 | 10:14 PM
low 66's Avatar
low 66
My truck had this 352 put in it by previous owner
Old Nov 12, 2010 | 10:24 PM
Bear 45/70's Avatar
Bear 45/70
Are you sure, because the 1966 trucks came from the factory with 352 engines?
Old Nov 13, 2010 | 06:12 AM
low 66's Avatar
low 66
They told me that they put this in it
