Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Why is My Truck Bouncing?
Guide to diagnose trouble and recommended solutions
Rear end bounces @ 40-45 MPH
#556
#557
Hey everybody, this is a heckuva thread. Spanning 3 years and a ton of info. I wanted to share my results, since this problem is pretty widespread the same fix might be able to help you 6.7 folks too. I have an '05 and even though Ford came out with their TSB for the damper, it doesn't help. My running theory had to deal with frame flex, and adding a crossmember took about 95% of the hop out! I'm still playing with another one to get rid of it completely, but it's soooooo much better, honestly if I didn't know better I'd swear it was just normal road vibration.
My Theory on the "Superduty Hop" and Possible fix. - Ford Powerstroke Diesel Forum
Chris^^^the blue is just an anti-corrosive/lubricant coating. It's still steel underneath
In my case, the vibration seems to originate from the driveshaft, feels like the carrier support area. The frame and suspension seem to amplify it. Even with a 2000# load of gravel in the back, the hop is dampened, but I can feel the evil gremlin wiggling under there. So if the tires or driveshaft are not perfectly smooth, we get a whole lotta shakin goin on (when it's unloaded).
Stiffening the frame is a great idea, that I'd also like to work on. I didn't know where to start, but you guys did a great job illustrating the weak spots. Amazing in your video, how you twisted it with one arm! Maybe someday Ford will make a stronger frame on these trucks. Can you think of any upside to having a weak frame like that? I can't.
Good call on that blue nylon coating, now I see the shiny center.
#558
Good stuff, thanks for sharing that! I read thru all 10 pages on the other site. I agree with and appreciate what you guys doing, but I also believe there's more going on. (At least in my case) Someone earlier in this thread called these trucks "hyper-sensitive" to vibrations. That is so perfectly accurate. When I pulled my drivehaft and drove around, I noticed even little bumps can shock and reverberate thru the truck. (Frame shake) What I didn't notice was the continuous vibration I normally get driving around at 44mph, that was gone.
I also think the vibration/shake is more towards the rear/carrier area, which is why I stiffened that area first and have had great results and I'll continue to try some other ideas I have.
I've been following this thread for awhile and it'll be great to see what you guys come up with over here. For awhile, it seems like we've all been treading water but maybe we're finally getting somewhere.
#559
Went to Dealership last week to see if they could fix the vibration. No such luck.
Service tech said they rotated and re-balanced the tires which did help a little
but still have the vibration. Really wish I could get this issue fixed. Really annoying and I worry about long term implications on the drive train.
#560
I had another service visit this week, and reached another dead end. Mine is ok sometimes, but bounces violently like a washboard other times. I asked them to look at the rear driveshaft, that I think it binds up under certain conditions. They went for a drive with a NVH analyzer and didn't pickup anything out of ordinary. Of course the truck was on it's best behavior, and they only did a 10min drive.
The tech stated a driveshaft/carrier bearing issue would repeat every time at the affected speed. He said his diagnosis is a 1st order wheel vibration, and I should go back to stock wheels. I'm really shocked they failed to prove this theory, with 10 new trucks on the lot they could have borrowed wheels from. The visit concluded in only 1.5 hours. I'm disappointed, because I spent more time just driving there. I was hoping for more testing, and at least give me a chance to reproduce the issue, but they sent me packing. I guess I'll be fixing this problem on my own.
#561
#562
As annoying as this is, before you jump ship, I would recommend checking the forums of other brands. You may be surprised at what issues the others are dealing with.
#563
Just frustrated with the issue.
#564
I studied both Ford and the new Ram for 4 months before making my purchase. After reading the issues with each, I am not sorry I made the choice I did. I have to admit though, while I was doing my research, it was a much tighter race than I had expected, but after reading about the current issues with Ram, the race isn't as close any more.
#565
I finally dropped the truck off this morning for the shudder/vibration issue. The Tech (aka my bro) submitted all the info to the folks at corporate. Tires balances-check, over GVWR/GCWR-No, suspension or wheel/tire mods-no. They came back and said replace the drive shaft with (BC3Z-4R602-MP).
I don't expect miracles on the 42-45 mph hop, but I hope it fixes the towing shudder as it was bad. I do believe the hop comes from the fact that you have a slip yoke, a carrier bearing with rubbing dampener and a u-joint all in the same location. Too many moving parts and then u-joint harmonics kick in and get amplified. Chris Stewart beat me to it (removing rear shaft), but confirmed the cause.
I did read through that other thread on the frame stiffening, but that just seems to bandage the real cause. It appears to help, but it seems to be present at small levels. Not to mention that DPF doesn't allow for a lateral-torsional brace under it without being well below the frame.
The new shaft will be installed next week sometime.
#567
I wonder if your new drive shaft will include new carrier bearing. Searching that new shaft part number I see posts on a few RV sites that say this new shaft is suppose to take care of the shudder on take off when towing, maybe it will fix the rear end hop at 45 mph too.
Please keep us posted!
#569
