Vacuum Line problem!
Old Nov 12, 2010 | 12:59 PM
85_4x4XL's Avatar
85_4x4XL
Hey there.. There's a 3 way line that goes from my egr/pvs valve. There's a line about 2 inches from the valve,and then there's a 3 way. One line goes to my egr valve on right side of the carburetor. Then the other line on the 3 way goes to the egr port on the left side of the carburetor! In the Chilton book it shows there is suppose to be a vacuum check vale there! Does that valve have to be there? Cause I just have a line running there right now,and if I turn my truck off after it's been running for a little bit,and let it sit for a few minutes,and then try to start it,it starts then dies and when it does stat it backfires and dies. But if I take the line off from the egr port and let it hang it runs just fine! So I was wondering if I need that vacuum check valve there to run it properly!
Old Nov 12, 2010 | 05:07 PM
Franklin2's Avatar
Franklin2
Are you sure it's a check valve? It might be a delay valve. I would assume whatever it is, Ford put it there for a reason.
Old Nov 12, 2010 | 06:26 PM
85_4x4XL's Avatar
85_4x4XL
Yeah it's the check valve. I checked to make sure it was a check valve a hundred times... So I should just buy a check valve and sees if it fixes it!
KsCop
35
Aug 11, 2014 03:25 PM
f100beatertruck
Jul 29, 2013 07:41 PM
ErrorS
Sep 7, 2007 10:43 PM
Hellbore
May 23, 2006 05:22 PM
fmc400
May 23, 2004 06:47 PM
