Would you??
Old Nov 12, 2010 | 10:47 AM
oldbird1965's Avatar
oldbird1965
Would you??
I'm going to be pulling the VC's to put in new glow plugs. Would you replace the uvc gaskets as a preventive measure? Mine have been there for 60-70K or so. Does the wiring get 'old'. Are the newer ones 'tougher'? Where is the best place to get new ones nowadays? Thanks
PS, where is a good place to buy and what brand of glow plugs?
Old Nov 12, 2010 | 11:02 AM
Talyn's Avatar
Talyn
Beru/motorcraft Zd11's.
You can pick them up from Clay at RiffRaff
if the UVCH's and the UVC are good, don't bother, nothing but wiring to go bad with them.
Old Nov 12, 2010 | 11:11 AM
Talyn's Avatar
Talyn
Riffraff Diesel: Motorcraft Glowplugs
Old Nov 12, 2010 | 03:17 PM
plgebbia's Avatar
plgebbia
Not to take any business from Clay, but if you need them ASAP, O'rielly auto parts sells the Beru plugs (if there is a location near you) for about $12.00 a piece IIRC.
Again, if you can, get them from Clay. Just thought I would through that out there,
Old Nov 12, 2010 | 03:31 PM
redman84's Avatar
redman84
What's the difference between the zd10s and zd11s? And can we use either?
Old Nov 12, 2010 | 05:19 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
There isn't a ZD10, it was probably a superseded part number. Number Dummy could probably give you the history on it.
Old Nov 12, 2010 | 06:18 PM
strokin'_tatsch's Avatar
strokin'_tatsch
yep, about $100-110 for the ZD-11's from O-reilly's. All autoparts stores will attempt to sell you the Autolite plugs, but DO NOT buy them.
Old Nov 12, 2010 | 09:34 PM
oldbird1965
OK, thanks a lot guys!! UVC gaskets good, ZD11's coming up.
Old Nov 12, 2010 | 10:24 PM
fordpride's Avatar
fordpride
If you go to O'reilly's tell them your a fireman there's a little discount it's not much but every little bit counts
Old Nov 12, 2010 | 11:09 PM
oldbird1965
Fireman, LOL!! With this beard and hair I'm a fire hazard LOLOLOLO Thanks for the thoughtful idea though.
Old Nov 12, 2010 | 11:20 PM
fordpride's Avatar
fordpride
Chief..........
Old Nov 12, 2010 | 11:26 PM
chicagodragon's Avatar
chicagodragon
'I' before 'E', mike.
Old Nov 12, 2010 | 11:27 PM
chicagodragon
Old Nov 12, 2010 | 11:36 PM
fordpride's Avatar
fordpride
My bad i fixed it
Old Nov 12, 2010 | 11:40 PM
oldbird1965
Good one!!
