03 Excursion 4x4 troubles
Old Nov 11, 2010 | 01:57 PM
jloucks01's Avatar
jloucks01
2003 6.0 Excursion my 4x4 has stopped working. when I turn the **** for the electric 4x4 I get nothing. no lights on the dash / no engage. Checked all the fuses all good there I swapped out the dash switch, no change. Replaced the t-case motor, no change either. the 4x4 lights on the dash check in when I start the truck but from then on I get nothing it seems like theres no power but I havnt been able to find a short, Need some help Im hoping that its not the GEM module. if anybody has Ideas let me know....... thanks guys
Old Nov 11, 2010 | 02:10 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Have you tired to manually turn the **** to lock the hubs? Does your heater/AC blow out the dash vents or does it always come out the defroster vent?
Old Nov 11, 2010 | 02:20 PM
jloucks01's Avatar
jloucks01
AC Is working properly. changes vents quickly when I select diferent functions. locking the hubs in does nothing either. I have no vaccume an the lines going into the hubs but im assuming the 4x4 power issue is going to contribute to there being no vaccume.
