EBPV ?
Old Nov 10, 2010 | 08:59 PM
bakerbuilttracks's Avatar
bakerbuilttracks
EBPV ?
So today i had some free time and had never dont the EBP tube and sensor clean. So i took the Tube off and at on of the bends it had a crack as i was cleaning it it got worse. The crack was 2/3 of the wat arround the tube. I was ablr to tie wire the tube back tight then jb welded it to seal the crack for now since i had no brazing rods. The tube was really packed and and the sensor aswell.
After reinstalling it seemes to have more pep. I will get a new tube on order and probly sensor too. But the question i have is what is the big effect if this system is not in good working order ex. like the crack in the pipe or it beeing clogged with soot. What effect will this have?
Old Nov 10, 2010 | 09:14 PM
woodnthings's Avatar
woodnthings
The parts you need are listed below. Give Ed a call. www.partsguyed.com He will hook you up.
EBP Tube 1C3Z9D477AA $39.42
EBP Sensor 4C3Z9J460A $78.90
Old Nov 10, 2010 | 09:18 PM
woodnthings
Having a bad tube or sensor can have ill effects on MPG and power. I have seen a few times where the sensor goes bad and messes up the 5 volt signal and causes a no start. Since the PCM monitors what is going on there, if you have a clogged sensor the PCM may make changes to correct it. Obviously you have the right EBP so it is making changes that it shouldn't.
Old Nov 10, 2010 | 09:24 PM
bakerbuilttracks
10.4 ken sounds good i will be gettin up with ed soon thats fairly cheap too. Truck ran ok before today and after the clean like i said it seemed to run abit better.
Old Nov 10, 2010 | 09:34 PM
woodnthings
Ed has some of the best prices I have seen......
OEM BABY
Old Nov 10, 2010 | 09:52 PM
PaysonPSD's Avatar
PaysonPSD
EBP is used by the PCM to determine engine load and if the Sensor is not sending an accurate reading fueling and SOI (start of injection) will not be optimal. This can and will affect MPG and power. This is why I don't think those who put in a fooler or open the Sensor to the atmoshere and cap off the EBP tube fitting at the exhaust manifold are doing the right thing. The best thing to do is to keep the EBP Sensor functioning properly. After cleaning the tube I replaced the sensor and keep the old one as a spare.
Old Nov 11, 2010 | 06:07 AM
bakerbuilttracks
Thanks Robin. I agree with you i was just a tad bit un shur how thw system worked exactly. Well guess im ordering a new tube then. THanks yall for all the help
Old Nov 11, 2010 | 10:02 AM
PaysonPSD's Avatar
PaysonPSD
Didn't mean to sound preachy, nor directed just to you.
I live at 5,000 ft and in a day may travel between 1500 and 7000 ft elevations
and want all the sensors working correctly for optimal performance.
Old Nov 11, 2010 | 11:58 AM
joeyd61's Avatar
joeyd61
Ken,
help me out, i looked up the part numbers and EPB senser came back for a 1999-2007 6.0L?????I am ablosutely no good with his site...is that correct for the 7.3 also??
Old Nov 11, 2010 | 02:49 PM
woodnthings
Looks like it is one of the sensors that is used on multiple engines. This is pretty common with our trucks.
Here is a capture of the search. It shows both 6.0 and 7.3 trucks for the same P/N.
As always verify what you order with them by using your VIN number to ensure you get the right parts.
Old Nov 11, 2010 | 03:16 PM
joeyd61's Avatar
joeyd61
thanks Ken, like i said for some reason me and that site don't work well together
Old Nov 11, 2010 | 03:18 PM
woodnthings
Something else to think about when using parts sites is they are not 100% accurate. I know I talked with Ed at SOTM 2010 and he mentioned that, so always provide your VIN when ordering.
Old Nov 11, 2010 | 05:32 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
AMEN BROTHER!
guthrie&co
Jan 25, 2009 10:03 PM
swaybar
Jan 25, 2009 05:35 PM
superduty4x4
24
May 8, 2008 06:10 PM
99powerstrokeSD
Jun 20, 2007 09:31 PM
Alpine6
May 13, 2007 02:47 PM
