Shudder when turning from stop only
Old Nov 14, 2010 | 03:30 AM
megafordf150's Avatar
megafordf150
Hey all
I just bought a 2004 f150 Supercrew XLT and the Mechanic that owned it had replaced the Dif with a Limited slip unit. He told me that it shudders when turning.. which it does and he also told me that he has tried everything to get it to stop with no success. I think he is a pretty strait up guy as well as a good mechanic so I was wondering if you guys have any words of wisdom for me.
Thanks in advance.
Old Nov 14, 2010 | 03:38 AM
Skip1970's Avatar
Skip1970
Originally Posted by megafordf150
Hey all
Thanks in advance.
change fluid
add friction modifier
if that dont help then rebuild your limited slip clutches.
Old Nov 15, 2010 | 08:33 PM
greg1971's Avatar
greg1971
Hey all
Thanks in advance.
If you are going to change the diff. fluids then use 75W140 synthetic fluid and add 8oz of friction modifier. I had a shudder in mine and I added just 4 oz. of the friction modifier and cleared it up 90% but changing the fluids would be ideal. You should also change the fuel filter every 30K miles and change the transmission fluid (especially if towing) every 30K with synthetic fluid.
Hope this works for you.
richlars
May 27, 2017 09:57 PM
F250TN
Nov 6, 2016 07:04 AM
NunchuckNorris
Sep 7, 2015 07:03 PM
abubba1
6.4L Power Stroke Diesel
Sep 27, 2013 06:12 AM
BeavisTheMighty
Jul 8, 2012 11:23 PM
