Pulline Engine/Trans Request Advice
Old Nov 10, 2010 | 06:10 PM
AmericanROCKBREAD!'s Avatar
AmericanROCKBREAD!
1956 W/272/Auto - I am closing in on my engine pull and have a couple questions before I proceed.
I'm pulling the engine and trans as a unit and assume this is standard/OK?<O</O
</O
Where do I attach the chains to the engine? Intake <O</O
Manifold/Exhaust/Accessory mounting?<O</O
<O</O
If anyone has any pointers, I will appreciate it! Thanks!<O</O
Old Nov 10, 2010 | 10:59 PM
Lakotas53's Avatar
Lakotas53
</O
Yep its usual practice to pull both motor and trans at the same time.
I have pulled motors by using a chain attached to the head using a
bolt on the exhaust manifold. But I installed a 351w and c6 trans in my 53
by using a lifting plate bolted right to the carb mounting base on the intake manifold. I sure was worried the first time I did it but it works great.<O</O
Old Nov 11, 2010 | 01:20 AM
Julies Cool F1's Avatar
Julies Cool F1
Take the exhaust manifolds off first then bolt up the chains. Cast manifolds will shatter if you put any force on them.
Old Nov 11, 2010 | 07:13 PM
AmericanROCKBREAD!
Got it out.
Got it out. Anyone recognize this transmission?
