spark plug number????
Old Nov 10, 2010 | 05:32 PM
tylerscott's Avatar
tylerscott
Im needing a picture that shows the wiring order for the spark plugs for my 2005 Ford Ranger 3.0L V6. I have looked through my chilton manual and cant find it... thought it would be in there.
If possible, it needs to have the order for the coil pack and for the spark plugs and the orientation of each( i.e. front of truck, passengers side, drivers side, etc.)
Thanks guys
Old Nov 10, 2010 | 07:05 PM
Danger_Dave's Avatar
Danger_Dave
if you are standing in front of the truck facing the engine, this is how the cylinders are numbered.
3-----------------------------6
2-----------------------------5
1-----------------------------4
passenger side<--------------->driver side
according to my haynes manual
for the distributorless ignition coil pack if you are standing facing the same way and look at it, this is the configuration for 1995-2008 3.0 v6 meaning the wires go from that spot on the coil pack to the corresponding cylinder
3 4
2 6
1 5
the firing sequence is 1-4-2-5-3-6
*in the 1997 ford powertrain/drivetrain manual i have, it states that certain wires will cross each other on their journey from the sparkplugs to the coilpack. this orientation must be maintained and you must always use wire separators.
this is to prevent inductive reactance "aka crossfire"
anytime you pass electricity through a wire it generates an electromagnetic field around itself, and when you have 2 similar wires close together running parrallel to each other they can have a tendency to **** each other off and cause misfires! if they cross each other along the way it counteracts this.
foxbody429
Mar 15, 2013 11:43 PM
kay2lkay
Jun 29, 2010 12:41 AM
Pathfinder1369
Jan 5, 2009 04:27 PM
vadphoenix
2004 - 2008 F150
May 5, 2007 12:18 PM
roc.r1
Jun 28, 2004 02:11 PM
