2150 Carb Jets
Old Nov 10, 2010 | 09:19 AM
sdarring's Avatar
sdarring
2150 Carb Jets
Hi all. I just bought a 78 F250 with a 400, and am trying to get it running right. The PO had set the timing at 37 degrees, ant the carb settings were all over the map. I re-built the carb, & re-set the timing to spec.
Now, the truck runs a lot better, but is still rich. I have the mixture screws set at 1 turn out, and am wondering if the PO might have changed the jets... Where can I find out what jets should be in the carb, & where can I source replacements if needed?
Also, I assume the jets are marked? I didn't think to look when I had the carb apart... I will look as soon as I know what should be there.
P.S. I am at sea level in Vancouver, BC if that makes any difference.
Thanks
Stacey
Old Dec 2, 2010 | 07:34 AM
yankeerebel's Avatar
yankeerebel
sdarring,
the jets are stamped with a number right on them. Can't remember if the numbers are visible when installed. Jet size is related to the bore size which is cast into the front, driver's side of the carb body. Should be something like 1.21, 1.23, etc.
Ask FMC400 or number dummy. Anyone with a parts manual can tell you what they should be with your bore size.
Old Dec 4, 2010 | 12:15 AM
zaaac's Avatar
zaaac
I believe my jets are 57.
Macs1964F100
Jan 20, 2014 09:37 AM
granny_rocket
Jun 29, 2013 07:43 AM
sdarring
Nov 9, 2010 09:45 PM
jdon88
13
May 21, 2004 09:12 AM
tamarackstyle
1978 - 1996 Big Bronco
Feb 18, 2002 08:59 AM
