05 Expy Overheating under normal conditions
Old Nov 9, 2010 | 12:02 PM
mikesocal89's Avatar
mikesocal89
Hey guys, new to this forum. Did some searching but could not find anything regarding the newer 5.4's overheating especially under normal driving conditions.
Here's the deal: Last week my 05 Expy was running rough, took it into the shop and the mechanic said an injector was stuck open, went ahead and had that replaced. A few days later it overheated (not pulling a trailer, not going up hill, maybe 70 degrees outside temp), all the lights came on including the reduced power. Had it towed into the shop where it measured 250 degrees. Shop called next day and said head gasket needs to be replaced.
From my understanding, the head gasket going bad is because of the overheating. Any ideas what would be causing it to overheat under normal conditions? Radiator is fine, no coolant in oil etc. Cant seem to find anyone else with similar problems (injector or overheating) with the newer version of the 5.4 Also, truck has 110,000 miles.
Thanks for the help
Old Nov 9, 2010 | 02:04 PM
pdqford's Avatar
pdqford
When was the cooling system last flushed?
Is the thermostat working correctly?
Is the cooling fan working?
(Someone that knows the '05 should be along shortly )
Old Nov 9, 2010 | 02:20 PM
alloro's Avatar
alloro
A blown head gasket can cause the engine to run rough and overheat. To me it sounds like the head gasket was the problem from the get go.
Old Nov 9, 2010 | 03:39 PM
mikesocal89
All scheduled maintenance has been followed, cooling system was last flushed about 100,000 miles ago. Cooling fan and thermostat are working.
Alloro, are blown head gaskets known for going out on these engines or is this weird at 110,000 miles?
The local ford dealer and a local shop told me that they don't normally see the head gaskets going on the 5.4.
My issue is, I would assume it will need a transmission within the next 40-50,000 miles and probably a fuel pump sooner than later. Any other repairs I should plan on/budget for on this truck within say the next 50,000 miles?
Edit: Spark plugs have already been replaced
Old Nov 9, 2010 | 06:40 PM
madsonp's Avatar
madsonp
Head gaskets can go out on any engine, the 5.4 being no different. If you do a search you'll see you're not the only one thats had head gasket issues. There is a product you might look into that could save you around $1000 if it works as advertised, however I don't know of anyone who's used it. You can find it here: Head Gaskets Repair : Blown Head Gasket : Head Gasket Replacement : Cylinder Head Gasket : SteelSeal.com If you do try this let us know how things turn out.
tomdowling
Jul 15, 2016 01:30 PM
noober0x
21
Oct 19, 2015 01:47 PM
Big Green 6.0
Aug 22, 2015 06:44 AM
cueball71
Feb 4, 2011 11:28 PM
at4rxj
Sep 18, 2009 05:48 PM
