Tire Question
Old Nov 8, 2010 | 10:31 PM
vtjvt's Avatar
vtjvt
Tire Question
Quick question, I have some 265/75/16 tires, am I going to have a problem running them on my 78 2wd? the rims I am getting have a 4.5 inch offset.
Old Nov 9, 2010 | 08:47 PM
vtjvt's Avatar
vtjvt
anyone???
from what I have searched they should work but I want to verify it before I lay down the cash for new wheels.
Old Nov 9, 2010 | 10:14 PM
AK FORD GUY's Avatar
AK FORD GUY
I see no real problem, but it's hard to say for sure because I have never personally ran them. The best way to figure it out is to jack your truck up, remove one of the wheels and do some measuring with the specs you have for the wheel. You did not give us the width of the wheel you are looking for, so it is hard to know if they will fit or not. If they are 16x8 with a 4.5" back spacing, they might work, the thing to watch for is a 265/75R16 is a fairly decent size tire, they will measure between 31" and 32" tall depending on the brand and tread left on the tire.
Old Nov 9, 2010 | 10:32 PM
vtjvt's Avatar
vtjvt
The wheels are 16x8, the tires are goodyear wranglers. I had them on my bronco and wanted something more aggressive. They only have at most 1,500 miles on them. I was hoping to save some cash since I already have these paid for
I know the 31x10.5x15 tires I have on the bronco now will swap over but the goodyears are about a inch taller sitting side by side.
Old Nov 9, 2010 | 11:03 PM
AK FORD GUY
If they are 1" taller when sitting side by side, they will only take up an extra 1/2" of the wheelwell as the 1" will get split because they are mounted from the middle. I would say they would fit just fine if the 31-10.50R15's fit with a little extra room to spare. A 265/75R16 equals about a 32x10.50R16.
Old Nov 9, 2010 | 11:18 PM
mdr617's Avatar
mdr617
Yes , they will fit. I have a set of 31"x10.5"r15 goodyear A/T tires on my 79 F100 2wd, all stock, and mounted on the stock steel wheels. the only problem i have had is when the wheel is turned fully to the right(maybe left, i forget) it slightly rubs a little. Besides that, no problems.
Old Nov 9, 2010 | 11:23 PM
mdr617's Avatar
mdr617
The tire size you said equals 31.6"x10.4"....Once again, that is if they are the exact size, but it varies by the manufacturer
Old Nov 9, 2010 | 11:25 PM
mdr617's Avatar
mdr617
And i did measure my stock 15" steel wheels, they have 4.5" backspacing, but the spare has 4" backspacing.
Old Nov 10, 2010 | 05:45 PM
vtjvt's Avatar
vtjvt
thanks everyone, I guess it is time to talk the wife into new wheels.
MCD46
Nov 21, 2013 05:55 PM
dionnfr
Nov 4, 2008 06:37 AM
EaglesGreenF150
May 5, 2004 01:00 PM
