Trans line routing
Old Nov 7, 2010 | 10:32 PM
Five-O's Avatar
Five-O
Trans line routing
Would anyone have a link or diagram to show the fluid lines routing on a E4OD with a factory tow package cooler. 1994 with 5.8L in that matters.
Thanks
Old Nov 8, 2010 | 06:40 AM
Scndsin's Avatar
Scndsin
Don't have either, but that's what I have. Is a verbal description OK? I'll have to take a look later to make sure its accurate.
Old Nov 8, 2010 | 08:56 AM
Five-O's Avatar
Five-O
sure , thanks
Old Nov 9, 2010 | 08:34 AM
Scndsin's Avatar
Scndsin
Sorry I've been slow getting back...
From the rearmost fitting on the back of tranny, tube goes forward to rubber tube splice. Metal tube continues forward & then up to passenger side entrance to tranny cooler mounted in front of AC condenser. Tube on drivers side of cooler goes down, runs under rad, then up to bottom fitting on drivers side of radiator tank just above lower rad hose. Top fitting comes out of tank, goes down, turns back toward center of engine compartment & turns back where splice tube is, Then runs back to front fitting of tranny.
Couple of things to note. The rearmost tube arches very high next to tranny where it exits ( to clear cat?) before comming down to run next to the other. They both also come in near contact to the exhaust crossover from drivers side manifold. Both tubes go through a bracket near the front of the engine block. I originaly thought the rubber splice was a non-original repair, till I removed it to drain a bit of fluid & found it bubble flared on both ends.
Hope this helps. Any other Qs, just ask.
Old Nov 9, 2010 | 09:55 AM
Five-O's Avatar
Five-O
That's awesome, one question, which way does the fluid travel when you drain the fluid? Is it leaving from the rear line to the rubber hose or coming from the rubber hose heading to the rear line?
Thanks
Old Nov 9, 2010 | 01:10 PM
Scndsin's Avatar
Scndsin
From what I remember, the front fitting (on trans) is the fluid out (to top of side tank, then cooler then back to trans) & the rear is the fluid in.
Old Nov 9, 2010 | 05:44 PM
Five-O's Avatar
Five-O
Thanks very much!
kyle1979ford
Aug 1, 2013 12:41 PM
hp246
Feb 8, 2008 04:11 PM
1stBronco
Jan 17, 2005 12:02 AM
tra
15
Feb 26, 2001 12:30 AM
