Have 9 codes need some help
Old Nov 1, 2010 | 01:25 PM
wulfman's Avatar
wulfman
Smile Have 9 codes need some help
Okay just finished EGR cooler hose and thermostat and fuel spring kit. So i was working on both sides of the motor. codes are po600,not sure of, po671- po678 got them all covered. I think these are glow plug circuit fault. Could i have hit or bumped something while doing the other work.Truck is 03 6.0
Old Nov 1, 2010 | 02:54 PM
dchamberlain's Avatar
dchamberlain
I'd guess (and some Google searches seem to support) that P0600 is a communication error. The other 8 are each glow plug.
Because you're getting all those codes, I'd have to say you managed to disconnect something going to the GPCM. If you disturbed the connector with the comm line, it may cause all those other codes. Maybe anyway.
I'd be looking at the GPCM connectors and wiring carefully.
Old Nov 1, 2010 | 03:37 PM
wulfman's Avatar
wulfman
Thanks David,should i be looking for a plug that came lose or what
Old Nov 1, 2010 | 03:43 PM
High Binder's Avatar
High Binder
Yeah, look for a pinched/pulled wire and maybe unplug then blow off the glow plug plugs and see if that helps. You may have leaned on the plugs while you were doing the EGR tube.
Old Nov 1, 2010 | 05:12 PM
dchamberlain
I think I'd be looking at the three connectors on the FICM themselves. Did you have to disconnect those? Or move the FICM? I'm not familiar with much of the EGR cooler stuff myself.
Old Nov 1, 2010 | 05:31 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
This is where wulfman was working for EGR hose. Anyone see what could have come loose while in these areas? Just wondering if the pictures might help. I don't have a clue.
And of course, the t-stat is in this area.
Old Nov 1, 2010 | 05:51 PM
wulfman's Avatar
wulfman
Okay checked everything i could see without pulling CAC tubes and intake stuff, everything looks good. Checked for codes all gone,meaning i erased them after writing them down. been driving it, they havnt came back. maybe distrubed something and now all is good. truck starts fine
Old Nov 1, 2010 | 05:55 PM
dchamberlain
Drive it. If they don't come back, you're all good.
Old Nov 1, 2010 | 06:03 PM
wulfman's Avatar
wulfman
thanks for info guys,will drive and see what happens
Old Nov 1, 2010 | 06:07 PM
amdriven2liv
Just curious, wouldn't the glow plug codes come right back after the first start? Or do they take a couple times?
Old Nov 1, 2010 | 06:14 PM
dchamberlain
It might take a few starts for the codes to be set again.
Old Nov 1, 2010 | 06:27 PM
wulfman's Avatar
wulfman
Ive started it 4 or 5 times today, going places. I have running around to do tommorow,will check for codes in evening to see if they come back
Old Nov 1, 2010 | 10:16 PM
mblack49's Avatar
mblack49
not to sound stupid but is it P0600 or P0060? My code reader is not that advanced and when the PCM throws P006A it come up as P0060. Good luck.....
Old Nov 2, 2010 | 12:48 PM
wulfman's Avatar
wulfman
Okay codes are back,when starting this morning hard to start like glow plugs were not on. on passenger side battery on hot side,small cable held on 10mm bolt was lose ,i did not tighten it when i had batt out before. could this have caused codes,and glow plugs not work
Old Nov 2, 2010 | 01:19 PM
dchamberlain
It sounds plausible. If your truck is like mine, the passenger side feed cable goes to the alternator. All of the vehicle power comes off of the drivers side (except for the large starter cable). If you were not getting alternator power during the glow plug cycle, you could have had a serious low voltage problem.
I'd make sure everything is good and tight and clean, clear the codes and try again.
