What engine?
Old Nov 6, 2010 | 09:29 PM
forkbeard69's Avatar
forkbeard69
What engine?
Hi guys,wonder if anyone can help identify what engine is in our 1977 F100 custom step side.The reg document says its a 351,but when I checked the firing order in the workshop manual it corresponds to a 302.Could it be a 351 with a different cam in it to give the 302 firing order? Can you tell a 351 from a 302 by looking at them?Thanks guys.
Old Nov 6, 2010 | 10:12 PM
HIO Silver's Avatar
HIO Silver
351 Windsor vs a 302? Yes. A 351W has a vertical casting rib near the distributor whereas the 302 does not.
If you've got a calibrated eye, a 351W also has a taller deck height.
Old Nov 6, 2010 | 10:45 PM
forkbeard69
Thanks HIO silver,I'll check that.
Old Nov 6, 2010 | 11:28 PM
HIO Silver's Avatar
HIO Silver
Are you sure you have a 351W and not a 351M.
Old Nov 7, 2010 | 05:49 AM
ford390gashog's Avatar
ford390gashog
The 4.6 enigne is a very easy swap. It has been done many times or you can go all out and swap in a new Ford 6.2 engine that is what I am going with.Just need to find the wrecked truck cheap enough at an insurance auction. I have a friend who is putting a 6.4 diesel in his 79 F-500 4x4 custom 6 door project truck.
Old Nov 7, 2010 | 08:38 AM
USArmyTaterness's Avatar
USArmyTaterness
Totally off jubject but is he making one of those like f650 super trucks? Just in the old body style?
Old Nov 7, 2010 | 10:30 AM
v8only's Avatar
v8only
IT Prob is a 351m....easy to tell..look at the location of the thermostat housing...comes right off the top...also the valve covers are wider
Old Nov 7, 2010 | 11:42 AM
forkbeard69
What's the difference between a 351 and a 351M?
Old Nov 7, 2010 | 12:39 PM
jim collins's Avatar
jim collins
351 m is a screwed up 400. 351w is a better engine. I know others won't agree , but that's the way I see it.
mrbillsadventures
Nov 2, 2016 07:13 PM
georgiafordman78
15
Oct 2, 2006 07:54 PM
ronboo
1978 - 1996 Big Bronco
13
Oct 19, 2005 12:03 PM
umdstang
Oct 19, 2004 06:18 PM
with
13
Jan 21, 2004 10:51 AM
