Jeremy......See what your strategy is after you reprogram your truck with the SCT to see if it changes. I was reading on another forum that some of the performance flashes were based on the VXCF7 strategy although I didn't know the SCT changed it. I know it can't affect the FICM programming in any way.
Mine comes up as VXCF7v3 when it is tuned. From what I heard when I got the tunes written, Innovative did not write tunes under the VXCF9N4 strategy at that time so they were writing them under the VXCF7v3 strategy.
The VXCF7v3 strat was part of the reason that I knew they didn't reflash it back to stock the first time around, that and my truck was still running like a raped ape. But after today's reflash I could definately tell it was back to stock.
Now I just got to reload my tunes on the SCT and retune my truck. And I will ALWAYS remember to return the truck to stock before switching between tunes.
...... And I will ALWAYS remember to return the truck to stock before switching between tunes.
That shouldn't be necessary. I've changed tunes probably 1000 times or more and the only time I go back to stock is when it goes to the dealership. It's basically just like reburning a rewritable CD, but not exactly.
I believe that if you are switching between custom tunes that were all written on the same strat you may not have a problem.
My problem came when I tried switching from a custom tunes that were written on the VXCF7v3 strat to a canned tune for the VXCF9 strat without going back to stock first.
I had a long conversation with some of their tech support guys and gained a little more understanding about tuners and tunes. They said that what had happened to me is not an uncommon problem, and that I should I always switch back to stock before changing between tunes. So just to avoid future problems, I think I will go that route.
That's interesting to know. I'll give Matt@SCT a ring and see what his thoughts on that are as I'm considering a major strategy change in the very near future. Thanks Jeremy.
Tim: changing back to stock before changing tunes is OLD news, ya know...
We discussed that around here a couple of years ago. The basic story was that re-writing a tune without going back to stock didn't re-write all the pertinent variables correctly, and you wound up with an unpredictable hybrid.
SCT swore up and and down that it wasn't necessary, and then later quietly took a step back and said it was better to write back to stock before a new tune.
We had a few fools swearing that you had to unhook the batteries and reset the KAM on every tune change, but that was beaten down pretty fast. THAT far isn't necessary.
....SCT swore up and and down that it wasn't necessary, and then later quietly took a step back and said it was better to write back to stock before a new tune.......-blaine
I had never heard that before and have never done that.....maybe I've been incredibly lucky and just didn't know it again....... It just takes SOOOOOO long to flash an 03/04 twice compared to the 05,6,7's and I've never had a problem. I will take it to heart though.
I have had many similar problems with the dealerships around SoCal thats why I just dont go to them anymore. My advice is to find a reputable shop in your area and never go back to the dealership again. I mean come on.... what diesel tech doesnt know what EGT's are? Unbelievable.
I was a jet mech in the US Navy for 20 years back in the day..... worked on the F8 - F4 - A6 and every one of them had EGT gauges in 'em. Sure can't call them ricers or gas engines! LOL
My '07 has never been objectionably long. But then, I'm also comparing that to flash devices other than truck ECM's...
-blaine
7-10 minutes for each flash (I know that sounds soooooo long--LOL) I was thinking that the 05,6,7's only took something like a minute to flash?? Still a LOT quicker than the 6.4's and I haven't even heard about the 6.7's yet.
