coil spring swap????
Old Nov 6, 2010 | 05:45 PM
bad390ford's Avatar
bad390ford
getting ready to swap my (f150 4.9 standard cab 8' bed) springs out with (f250 5.8 standard cab 8' bed) coils, i already know that i most likely will need alignment afterward, but questions i have are, will i need to shim rear leafs or not, and if you know, how bad is it pulling bottom nut?, or should i just save myself some grief, burn 'em and buy new nuts and bolts? and if so what grade strength is required? ps both are 2wd...
