Sponsored by: Real Truck
BEST SETTING'S FOR HYPERTECH 42000
Old Nov 6, 2010 | 12:34 PM
CALIF-F250MAN's Avatar
CALIF-F250MAN
Hello all,
Am new here so bare with me, I have a 2003 F250 w/5.4L(ya I know) w/ a 4" lift BFG AT 315/75/16 TIRES stock gears auto 4x4. I have installed a cooled air intake system, throtle body spacer also. I just purchased the hypertech 42000 to install in my truck. What am looking for is the best setting suggestion for it. I pull a 31' trailer that weights about 6000lbs. Any help would be great. Thanks again.
Old Nov 6, 2010 | 03:12 PM
CALIF-F250MAN
Or did I just purchase the wrong programmer? Any help would be greatly app..
Old Nov 8, 2010 | 09:07 AM
Fishin76's Avatar
Fishin76
Welcome to FTE!
Most 5.4L guys on here that want a tuner do not get a off-the-shelf tuner, and there are not many OTS tuners for the 5.4 for the SD's anyway.
I'm sure that Mike at 5-star Tuning could help you find a good tuner for your SD. I have heard of the Hypertech tuners, but never had any experience them.
Maybe someone else will speak up about the tuner you have.
Old Nov 8, 2010 | 09:18 AM
1ford1's Avatar
1ford1
Ditto on Mike at 5 star. I have no knowledge of the Hypertech.
Old Nov 8, 2010 | 09:43 AM
KhanTyranitar's Avatar
KhanTyranitar
I have a little knowledge of the Hypertech, but an off the shelf unit will not be fully able to take advantage of your mods. An off the shelf tuner is great for a stock truck. The benefit of the Hypertech is the number of tunes it can store, allowing you to use it on many vehicles, even different brands.
Old Nov 8, 2010 | 09:46 AM
TBFGhost's Avatar
TBFGhost
Did you honestly see any difference with the TB spacer? I find it hard to belive those things do anything...
Old Nov 8, 2010 | 10:45 AM
CALIF-F250MAN
I did notice a difference, more on hill climbs then anything.
Old Nov 8, 2010 | 10:56 AM
TEAM HARD's Avatar
TEAM HARD
First... "Stock gears" means nothing if you dont list the ratio since Ford offers more than one differential.
Second, see Mike at 5-Star as others have said... they specialize in the Ford gas powered SD's. That Hypertech, while I dont know much about them specifically, is probably garbage next to what Mike can do... custom tunes for you, based on what you do.
5 Star Tuning | Custom Dynomemeter Chassis Tuning Products and Services
Old Nov 8, 2010 | 11:35 PM
02mudbug's Avatar
02mudbug
If you are planning to use a 5.4 powered truck as a tow rig with 35s hopefully you can find a tuner that will locate the nearest gas station for you at all times. I would send the hypertech back and take that money to pick up a set of take off rims with 235/85s on them for towing time. no tuner on a gas truck is going to make up for the difference of those big tires. your brakes will work better too. I speak from experience. i had a 02' reg cab with a 5.4 auto and 315/75/16s.
Old Nov 9, 2010 | 08:45 AM
KhanTyranitar
Agreed, if you want to run oversize tires, you need to change the gears, otherwise you are going to be slow and underpowered, and you are going to repeatedly kill your transmission.
Old Nov 9, 2010 | 10:06 AM
CALIF-F250MAN
what ratio of gears would you recommened? Am no gear head so this is all new to me.
Old Nov 9, 2010 | 10:10 AM
CALIF-F250MAN
The gas issue am not worried about it's more the power. Would love to sell the truck and go diesel .
Old Nov 9, 2010 | 10:21 AM
WestxSRT10's Avatar
WestxSRT10
Your best bet may be to do what I did...sold my off the shelf tuner (Superchips Cortex, it did more bad than good) on EBay. Mike at 5Star wrote 3 tunes for me with real pulling power results.
Old Nov 11, 2010 | 01:46 PM
402xjeeper's Avatar
402xjeeper
Hypertechs are a good unit, they are a good company, however a generic tune will never give the results of a custom tune. I ran the hypertech on two of my 5.4 f150s with good results, the transmission tuning is the most important thing for towing. on a gas motor you want to be conservative, get there slower without burning something up. PS; I hope that you have 4.30 gears, my stock f150s on stock tire w3.73 towed my popup poorly when climbing, went back to a sd powerstroke. semms overkill for a 5000lb load but I do not like to slow down (weekends are short enough already).
Old Nov 11, 2010 | 04:15 PM
ken kenmnedy's Avatar
ken kenmnedy
hypertech has a web site and a tech support number first you are gona have to look in side the drivers door and get the gear code and check it in the tech folder at the top of this fourm or you wont get the wright tune...I like my hypertech but if I would have known about custom tunes maybe I would have done differnt
