Water Pump
Old Nov 6, 2010 | 10:54 AM
65F100390's Avatar
65F100390
Water Pump
I am buying a new water pump today to put on a 352 in a ford F100, any tips or tricks I should know, this is my first one, thanks guys!
Old Nov 6, 2010 | 11:44 AM
tbm3fan's Avatar
tbm3fan
Well, do you hate water leaks? If so then make sure the the water outlet positions on the block are clean of gasket and oils. Scrape and lacquer thinner. When I put on the gasket I use 3M Super weatherstrip adhesive. Black or yellow doesn't matter. A line around the block face and a line around the gasket, let it tack and put in place. Then the same to the other side of the gasket and the water pump flanges. Also around the bolt holes. For bolts that go into the water jacket I use ARP thread sealant after cleaning bolts and chasing threads in the block. A FE is a piece of cake to do when you get down to it so should be no problem. Compare this to my Polara where water came out of bolt holes I didn't expect. Yet no leaks once it was filled back up. Oh, in case you wonder how to remove the adhesive, 3M sells a can of remover which does work.
Old Nov 6, 2010 | 12:23 PM
OldHarley's Avatar
OldHarley
Don't fail to replace that 3" piece of hose to intake manifold.
That can only be done while the pump is off.
Old Nov 6, 2010 | 01:11 PM
65F100390's Avatar
65F100390
Good call on that hose, forgot all about that!
Old Nov 7, 2010 | 04:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
By pass hose, waterpump to intake manifold. It's the same size as the heater hoses, 5/8"
There is a 5/8" nipple that is pressed into the intake manifold that the by-pass hose clamps onto.
When you remove the old hose, don't be surprised if part of nipple comes along with it, as it tends to rust out.
You can buy a replacement in autoparts stores, but it's "cut to fit." If the local parts stores don't have one...
C5AZ8555B (replaced C5AZ8555A) .. By Pass Tube / 5/8" O.D. / 2.50" long-cut to fit / Obsolete
BOZEMAN FORD in Bozeman MT has ONE = 406-587-1221.
LARAMIE FORD in Laramie WY has ONE = 307-745-7315.
SOEBY MOTORS in Walhalla ND has ONE = 701-549-3711.
SNOWY MOUNTAIN MOTORS in Lewistown MT has TWO = 406-538-4014.
chermansr
Nov 1, 2013 03:22 PM
ItsMREMT
Sep 20, 2013 08:09 PM
Greg9321
Feb 4, 2013 10:12 AM
Hotrod_ace
Jan 27, 2010 06:38 PM
colesdad
Jan 23, 2009 01:25 AM
