Sponsored by: Real Truck
Blower motor
Old Nov 5, 2010 | 08:53 PM
1ford1's Avatar
1ford1
Blower motor
99 F250, V10. AC blower not working on any setting. I have installed a new fan switch and rheostat. If I jump across the relay terminals, fan works. Relay is good. What engages the relay? At the dashboard control switch, using a test light, I have power. When I select any of the AC options, the test light also shows power on the wire next to the constant power. The control switch has 4 wires. The bottom two wires do not light up, no matter what I do. I have checked the relays and the fuses. Any help would be appreciated.
Old Nov 6, 2010 | 06:59 AM
1ford1's Avatar
1ford1
Please guys, a schematic maybe? Or a link?
Old Nov 6, 2010 | 08:15 PM
1ford1's Avatar
1ford1
Thanks guys, I figured it out
Old Nov 6, 2010 | 09:21 PM
dchamberlain's Avatar
dchamberlain
So what was it? I didn't answer cause I didn't have a clue. Reporting your answer may help someone in the future.
Old Nov 7, 2010 | 05:22 AM
1ford1's Avatar
1ford1
A combination of issues. A bad rheostat, fan switch, and a bad fuse (not blown though, just didn't work????). I once had a fuse in an audio system that worked until it became the least bit warm then it would quit, so I replaced all fuses and the relay. I hope this might help someone.
