return lines
Old Nov 5, 2010 | 10:49 AM
rum runner's Avatar
rum runner
return lines
Hey guys got a question, I installed new return lines and caps, and they leaked bad, so I replaced the o-rings with vition fluoroelastomer #111,
now they don`t leak unless I touch the cap, if i wiggle the cap they leak is this normal? any help would be greatly appreciated...thanks.
the truck is a 89 7.3 f-250 210,000 on the clock, 5 spd, 4x4,
Old Nov 5, 2010 | 12:15 PM
greywynd's Avatar
greywynd
O-rings of any material (either Buna-N or viton) tend to get hard with heat and time. They lose some of the elasticity that they start with.
Viton has a higher temperature rating, but they still lose their elasticity. Best thing to do when you replace the return line kit is to replace it, and leave it, in other words, don't disturb it. If you do, plan on having to replace the rings again.
It could also be a cracked cap. I haven't had that on any thing I've worked on yet, but several on here have.
Old Nov 5, 2010 | 12:18 PM
Sycostang67's Avatar
Sycostang67
Does it only leak while you are touching it? That would be expected. I put viton rings on my truck about 8 months ago and have removed and installed the caps 3 times with the same rings and they still dont leak.
Old Nov 5, 2010 | 12:21 PM
rum runner's Avatar
rum runner
Yes they only leak ti you wiggle them up and down, so as long as they dont leak other wise they are ok ? thanks again
Old Nov 5, 2010 | 12:29 PM
Sycostang67
Yeah, when you wiggle them you are breaking the seal. If they dont leak otherwise, they are fine.
Old Nov 5, 2010 | 01:00 PM
rum runner's Avatar
rum runner
Ok thanks so much sycostang67 on to the next project.
Old Nov 5, 2010 | 01:17 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
yeah don't even touch 'em if they don't leak.
just keep inspecting them when you check your oil.
for a little while,if you notice one leaking,you can replace the cap real carefully,leaving the Vitons alone.i did this a couple times.
now that they have been on there a while,i wouldn't try it.
id replace the whole kit again now if i saw leaks.
chh
Jun 11, 2014 08:37 PM
hondarider10
May 25, 2012 10:20 AM
hairyboxnoogle
Sep 14, 2011 11:23 PM
mlouritt
Mar 1, 2011 05:47 PM
Hand Clutch
Jun 15, 2010 11:35 PM
