Head gaskets and Studs, To resurface or not to resurface heads
Old 11-06-2010, 06:26 PM
69cj's Avatar
69cj
69cj is offline
I also recommend that you have the heads magnafluxed. Fuel leakage has been traced to cracked heads. Also the cost is cheap compared to pulling it down again and new parts.
Old 11-06-2010, 09:38 PM
vlietracer64's Avatar
vlietracer64
vlietracer64 is offline
During some routine maintenance i have sent the antifreeze and oil to blackstone for reports and show no fuel in oil and no containments in antifreeze, heads and gaskets seem to be great, but before i install turner i am putting in new gaskets and studs
Old 11-06-2010, 09:57 PM
vlietracer64
Originally Posted by vlietracer64
During some routine maintenance i have sent the antifreeze and oil to blackstone for reports and show no fuel in oil and no containments in antifreeze, heads and gaskets seem to be great, but before i install turner i am putting in new gaskets and studs.fficeffice" /><O></O>
But i do agree a cheep insurance to have them checked. dont want to take them off again
Old 11-14-2010, 08:45 AM
HeavyTow's Avatar
HeavyTow
HeavyTow is offline
Originally Posted by cheezit
have done lots of heads and most are in spec.
also refer to the engine section of the book for the warpage checks as it has changed, that spec copmes from the tsb.
Cheezit, are there any indicators concerning how bad head gaskets leak that gives you any forewarning as to out of spec head warpage? Have you seen any patterns that would give someone any idea what to expect before they pull it apart? I'm only seeing evidence of head gasket leakage under heavy load and was trying to calculate for a worst case senario befor tearing into the engine. What's the cost of a new set of heads for the 6.0?
Old 11-14-2010, 09:18 AM
cheezit's Avatar
cheezit
cheezit is offline
new way to tell how bad they will be.
dealer procing on heads I think is about $1600 ea. but I really bad a the pricing game. best bet is to call a dealer and ask.
Old 11-14-2010, 10:11 AM
HeavyTow's Avatar
HeavyTow
HeavyTow is offline
Thanks, I didn't know if there would be any obvious patterns or not. No wonder the heads are decked so much at that price.
Old 11-14-2010, 02:10 PM
1_BIGMOFO's Avatar
1_BIGMOFO
1_BIGMOFO is offline
I guess I should have done a little mor research before I spent $1400 getting my heads done...
Old 11-14-2010, 03:31 PM
vloney's Avatar
vloney
vloney is offline
I was looking at a video from Ford the other day in which they said, and I quote "Warped heads are a rare occurrence".
Old 11-14-2010, 04:52 PM
cheezit's Avatar
cheezit
cheezit is offline
that has been my finding as well. im sure yours about matches does it not?
Old 11-14-2010, 05:12 PM
bismic's Avatar
bismic
bismic is online now
Received 2,496 Likes on 1,733 Posts
<TABLE style="WIDTH: 339pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=452 x:str><COLGROUP><COL style="WIDTH: 339pt; mso-width-source: userset; mso-width-alt: 15968" width=452><TBODY><TR style="HEIGHT: 25.85pt" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 339pt; HEIGHT: 25.85pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=34 width=452>New Cylinder Head Check Procedure Video</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 410pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=546 x:str><COLGROUP><COL style="WIDTH: 410pt; mso-width-source: userset; mso-width-alt: 19296" width=546><TBODY><TR style="HEIGHT: 25.85pt" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 410pt; HEIGHT: 25.85pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=34 width=546 align=left>New Cylinder Head Check Procedure Video
Warped heads are a rare occurrence - at 4:28
Old 11-14-2010, 05:37 PM
69cj's Avatar
69cj
69cj is offline
That was good info Mark, that you can only check flatness on one plane.
Old 11-17-2010, 04:40 PM
vlietracer64
Checked heads saturday night and all checked and cleaned well, i actually used the .002" feeler guage to start and none of the 13 spots were loose whjile using it. Have heads and studs in, motor was 100% as of last night, installing cab tonight, Prob would have had it done over the weekend, but during assembly saturday i found an oversite, i forgot to order rubber gasket between head and rocker box, so truck had to sit and wait till monday.
  #28
Old 11-24-2012, 03:07 PM
miteldan's Avatar
miteldan
miteldan is offline
what about doing just a regular valve job? I got a 2006 f350 4x4 6.0 I have the engine out heads off
  #29
Old 11-24-2012, 05:41 PM
6.0techwannabe's Avatar
6.0techwannabe
6.0techwannabe is offline
I own a small diesel shop and work soley on the ford diesel lineup. When heads come off there sent to a reputable machinist. If they are more than .008 out they get replaced. .008 is pushin it tho. from expeirence,heads shoulds always be milled or replaced when removed. No exceptions with me. Btw....ford says .004
  #30
Old 11-24-2012, 05:44 PM
6.0techwannabe
You got em off..psi check em,mill em,replace valve guides and reseat valves. No reason not too.
Quick Reply: Head gaskets and Studs, To resurface or not to resurface heads
