need help fast!
Old Nov 4, 2010 | 01:50 PM
stephendudra's Avatar
stephendudra
need help fast!
I am wanting to buy some 22 inch eagle alloy wheels from someone. He has a 2005 F250 2WD.
Will these fit with NO issues on my 2003 Ford Excursion 2 WD???
Please let me know ASAP!!!!
Stephendudra@yahoo.com
Old Nov 4, 2010 | 03:42 PM
ford2000ex's Avatar
ford2000ex
oh they will fit with ease. but your tire size.. wont be big unless u got a lift. im runnin 20'' kmc rims on some nittos 275/55/20 and ive already cracked two, and these tires rub already on my stock suspension( big rims on big suvs, just aint the way to go on this one)
Old Nov 4, 2010 | 03:45 PM
TYZ78F150's Avatar
TYZ78F150
Might wanna do a little more research. The consensus is that factory SD rims after 2004 need spacers to clear the calipers correctly. They're expensive too. $600 and up. Might just be on the 4x4's though. Someone else will chime in i'm sure though.
Old Nov 4, 2010 | 03:47 PM
stephendudra
Thanks for the tip! ANYONE else??? I need to make a decision by tomorrow morning.
Old Nov 4, 2010 | 03:52 PM
stephendudra
The tires installed are as followed.
285/50R22
So your saying that with a 22 in wheel and these tires it will rub? If so, then I am not going to consider 22's and if you have 20" and they rub, then I guess my original plan of 18" might be the way to go then.
UGH!!!! Decisions Descisions............
Old Nov 4, 2010 | 04:04 PM
ford2000ex's Avatar
ford2000ex
ill take some pictures right now n ill post them tonight,, and you will see .
Old Nov 4, 2010 | 05:04 PM
robd827's Avatar
robd827
Ok I bought the spacers from a guy in caifornia. They are 2" spacers. You MUST have these for the correct offset. I run a set of 2010 King Ranch f250 rims 20" on 305/50 r20. They fit perfect and are spaced correctly. Search the site for the spacers or I can give you the web address when I get home. Yes they were $600. Rims were $1400. Ugh
Old Nov 4, 2010 | 05:22 PM
ford2000ex's Avatar
ford2000ex
i also rubb on my front sway bar.. at full turn
Old Nov 4, 2010 | 08:48 PM
jasonodsky's Avatar
jasonodsky
Nice frame polish
Old Nov 4, 2010 | 09:03 PM
RACERX7775's Avatar
RACERX7775
I have a set of 325/50/22's on my X. it is a 4x4. no rub on the frame. no spacers behind the wheels. Heavy rub on the front leaf springs. Wouldn't trade it for the world though.
Old Nov 4, 2010 | 09:07 PM
ford2000ex's Avatar
ford2000ex
dude, let me say you have one badass x, that black is nicely taken care of, do you wax her? or jus a wash &dry?
Old Nov 4, 2010 | 09:15 PM
RACERX7775's Avatar
RACERX7775
Thanks. wash, wash, wax, polish, wash, wash...... now has 145,000 miles on it. Its in the body shop getting a brand new paintjob now. some *** keyed the entire truck. Im doing a twotone paint job.
Old Nov 4, 2010 | 09:19 PM
ford2000ex's Avatar
ford2000ex
ouch what kind of wax & polish do you use, beats a brick hitting your door :0 . bunch of haters,
Old Nov 4, 2010 | 09:27 PM
RACERX7775's Avatar
RACERX7775
pep boys car wash soap with some kind of wax beads in it. macguiars carnuba wax. liquid glass polish. and between waxes, i use ardex spray wax after i wash it. oh, i wash it usually twice a week.
Old Nov 4, 2010 | 09:54 PM
Peace2Peep's Avatar
Peace2Peep
Yes racers truck is amazing and he alone inspired me to go big or go home...so I went big baby! I gotta do some rear fender well trimming but not too much. My wheels don't hit leafs at all but I've got a totally different offset. Offset is the key! What is the offset of your wheels? 4.5 inch backspace is perfect or near it. Width is also a consideration. Mine are a bit wide at 22x10.5.
