Interior Paint
Old Nov 3, 2010 | 06:42 PM
rmalottwtes30's Avatar
rmalottwtes30
Interior Paint
I been wanting to re paint my interior, I tried some of the rustolium and duplicolor interior paint and on the arm rests it only lasted a day. Anyways I really want a darker tan, like the tan from the Eddie Bauer edition trucks. Are more colors available for out trucks?
I am going to go pick up some Eddie Bauer door panels tomorrow, if there still at the junkyard.
Can I use regular paint for plastic?
Old Nov 3, 2010 | 07:14 PM
91chevywt's Avatar
91chevywt
I wouldn't paint or dye any areas that get touched on a regular basis, like armrests, steering wheel, or seats unless you would want to do it again every now and then. For interior plastics, it's best to use an interior dye/paint that is specifically made for that.
I used a duplicolor spray, with interior primer, and it is holding well on a center console I did. I scuffed it up very lightly with steel wool to help it hold also. I wouldnt use regular spray paint, as it will come off pretty quickly. The plastics need to be able to flex. I've seen cars in the junkyard people tried customizing with regular spray paint, and the paint was flaking and cracked.
Old Nov 3, 2010 | 07:25 PM
rmalottwtes30
The whole door panel is holding up all except the armrest, I dont want to leave it a different color, are they removable?
Old Nov 4, 2010 | 05:17 AM
TexasGuy001's Avatar
TexasGuy001
I would not paint any interior plastic, vinyl, or rubber surface. It does not hold up and just ends up looking horrible.
The arm rest is removable.
Old Nov 4, 2010 | 09:15 AM
Hitokori's Avatar
Hitokori
and yet again it depends on the paint u use and the work u put into it... my door handles are holding up great.... still glossy black same with the speaker grills
Old Nov 5, 2010 | 05:31 AM
TexasGuy001
I still think in a few years it will start to come off. Almost everything I have seen done turned out that way.
andy9743
Dec 2, 2015 05:13 PM
ilovemybronco
1978 - 1996 Big Bronco
Nov 7, 2014 06:14 PM
23racer
Dec 10, 2013 05:01 AM
RussF350
Dec 6, 2012 03:20 PM
skytower31
Aug 12, 2009 05:25 PM
