Truck down
Old Nov 3, 2010 | 01:29 PM
lionsteve's Avatar
lionsteve
Truck down
Symptoms: Truck will not turn over. Starter doesn't even turn. Lights do not dim. There is a click in engine compartment when key is turned. Batteries are new. Don't have anyway to see codes since it is dead in the driveway.
Could this be the dreaded CPS problem or are we looking at a bad starter?
Thanks,
Steve
Old Nov 3, 2010 | 01:42 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
CPS will not stop the starter from working. Have you tried giving the starter a tap with a hammer? That used to work for me 40 years ago. lol
clintbonnie's Avatar
clintbonnie
No... not a cps.. check and clean your battery connections 1st..
Old Nov 3, 2010 | 01:54 PM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
If the engine won't turn over it is starter or starter solenoid related, could be wiring, neutral safety switch. just a few things to check. If you take the starter off, most any auto parts store will benck check it ( for free ). IT would be good to check the battery voltage before you pull the starter. My guess it is a starter or solenoid
The CPS won't come into play until the engine turns over.
Old Nov 3, 2010 | 03:04 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
If it's clicking then the solenoid is working. Unless the batteries are weak i'd say starter.
Old Nov 3, 2010 | 03:10 PM
Joelong258's Avatar
Joelong258
As dumb as it sounds make sure your all the way in park. One day the pointer was on P but it was somehow halfway between that and reverse and my truck did the exact same thing.
Old Nov 3, 2010 | 03:14 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
What year truck? I think in '01 they changed the wiring so that the solenoid was on the starter itself. Prior to that, it was on the passenger fender. I had my solenoid crap out and bought a replacement from NAPA/AutoZone/Checker... can't remember which, but I'll say this: BUY THE OEM MOTORCRAFT PART.
Old Nov 3, 2010 | 03:32 PM
clintbonnie
According to his profile.... it is a 2000
Old Nov 3, 2010 | 03:38 PM
Bob Taulbee
Duct Tape Tech.
The solenoid can make the clicking sound and not put power to the starter.
Old Nov 3, 2010 | 06:53 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
[QUOTE=Bob Taulbee;9514702]The solenoid can make the clicking sound and not put power to the starter.[/QUOTE
Yes you are right!! I was thinking of the switch itself, but you are right it might not send power to the starter. Stupid me lol.
Old Nov 3, 2010 | 07:01 PM
dn29626's Avatar
dn29626
Be careful.Be careful.
Crawl under the truck with a piece of wire. Clip one end to the cable from the battery and the other end to the contact where the tiny wire connects to the starter.
If the starter does nothing, you have a bad starter (or bad battery connection). If the starter cranks the engine, it's likely a soleniod.
Old Nov 3, 2010 | 07:03 PM
Bob Taulbee
Duct Tape Tech.
[quote=Jmatthews;9515688]
No problem,
Old Nov 4, 2010 | 10:02 PM
lionsteve's Avatar
lionsteve
Well knocked the starter with the hammer and she started right up. The truck was my son's 2002. Got a 2 bolt starter, $200, and installed. All good now. Thanks to everyone for the help. FTE strikes again.
Steve
Old Nov 5, 2010 | 01:02 AM
clintbonnie
Thx for reporting back on your fix..
