Shudder while turning
Old Nov 3, 2010 | 12:29 PM
viking89's Avatar
viking89
Hi guys
I've just noticed this issue in the last couple of days. When I am at very low speeds, pretty much crawling along in traffic and I am turning the wheel I got a strong lateral jerk from the truck. It feels like it is somewhere in the rear. After the jerk happens, the truck will continue to roll along smoothly, then another jerk will happen. It almost feels like its happening in a specific spot as the drive shaft turns.
The jerk never happens if I am not turning. I've done some research and it seems that changing the diff. fluid is a good first step. Has anyone ever encountered anything like this before and has some advice on some things I could check?
My truck is 2wd dually with a 4.10 rear end. Not sure if it is posi or not.
Thanks
Old Nov 3, 2010 | 12:37 PM
thomabb's Avatar
thomabb
If you don't know how old your differrential oil is, I'd say start there. Sounds like the limited slip isn't slipping.
Old Nov 3, 2010 | 12:41 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You should have limited slip on your Dana-80 rear end. Your clutches may be going bad. I would change the fluid and add the friction additive. Look on the tag and it should tell you if it is LS or not.
Old Nov 3, 2010 | 02:09 PM
viking89's Avatar
viking89
Ill check the rear-end tonight. When I bought the truck back in April it needed a new pinion seal. The dealership I bought the truck from replaced the seal and filled up the diff. but I don't know if they added any friction additive. Probably best to just replace it all to be sure. Good excuse for a new diff. cover
If I do have bad clutches what am I looking at to get them repaired?
Old Nov 3, 2010 | 02:19 PM
miller_feed
If they changed the fluid, I would just get the additive and add 2 oz, then drive it to see if it stops. If it still does it, add 2 more oz.
Old Nov 3, 2010 | 02:51 PM
bulla's Avatar
bulla
Or you could pull the cover and see if there's anything major going on. Then try the additive. Then you'll know just what you've got in there.
Old Nov 3, 2010 | 03:04 PM
viking89's Avatar
viking89
What if my clutches are going out? What does that usually cost to fix?
Old Nov 3, 2010 | 05:03 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Do you still have the paperwork from when the fluid was changed? It might tell you what fluid was used. I'd try just adding some of the FM, 2 oz. at a time as others suggested. It's ~$7 for 8oz. and pretty cheap fix. Hope that's all it is.
Old Nov 4, 2010 | 08:11 AM
viking89's Avatar
viking89
I still have the paperwork. I'll check it when I get home. But I'm willing to bet they didn't add any friction modifier. Hopefully adding some will fix my problem.
Thanks
Old Nov 15, 2010 | 08:34 AM
viking89's Avatar
viking89
Just an update...
Added 4 oz on friction modifier and that seems to have fixed the shudder.
Thanks for the help
floppywater
Jun 12, 2014 05:59 AM
mblanken881
Jan 17, 2012 09:27 PM
glkearns
17
Nov 23, 2008 06:38 PM
tom_foreman
Aerostar
21
May 19, 2006 08:57 PM
ZachsTonka
Sep 27, 2002 08:51 AM
