looking for ZF shifter boot
Old Nov 3, 2010 | 09:01 AM
fishmanndotcom's Avatar
fishmanndotcom
i am in the middle of rebuilidng my zf s547 and cant track down a couple of parts i need. first is the shifter boot... not the boot that you see in the cab but the boot that actually seals the elements from the shifter housing. mine is all tore up and would like to replace it before putting it all back together.
it's this guy here:
http://www.thedieselstop.com/faq/949...j/stj73b18.htm
also i need the two rubber sleeves that go on the 4x4 shifter. the shifter mechanism has some nasty grease and i want to put new boots on it after i clean it up and add fresh, new grease.
thanks guys
-cutts-
Old Nov 3, 2010 | 10:36 AM
RRranch's Avatar
RRranch
I ordered all of that from LMC for my sons truck last year. You really need that white shifter boot unless you like a lot of noise in the cab. I was about to order one for my truck too. They still show them in the catalog.
Old Nov 3, 2010 | 03:30 PM
strokin'_tatsch's Avatar
strokin'_tatsch
The white boot your talking about comes with the whole shifter boot assembly that screws to the floor. I just had to get a new one and it all came together. Screws and all. I didn't get the boot that the OP is needing though. I'm sure LMC has them though. How about PartsGuyEd???
Old Nov 3, 2010 | 04:29 PM
fishmanndotcom
ahh, i forgot about LMC, thanks. i will check them out.
Old Nov 3, 2010 | 07:21 PM
fishmanndotcom
didnt see anything in the LMC catalog anywhere else i can try?
Old Nov 6, 2010 | 10:35 PM
fishmanndotcom
hopefully to help out someones future search i have the exact part numbers from ZF. the boot i am referring to is part number 1317 306 014 found in the Shift lever Stub assembly. motive gear sells them but dang they are pricey at $50. but it will help keep dirt and gunk from entering the top of the transmission. expensive but cheap insurance all at once!
http://www.autopartsdealer.com/motiv...p910454-p.html
also, you can reference the part number in the website below to see exactly what i am referring to:
http://www.zf.com/na/content/media/u...SpareParts.pdf
-cutts-
OldWoodsDiesel
WTB - Parts & other
Jun 11, 2016 12:47 PM
danr1
Aug 3, 2014 05:42 AM
big ole ford
Jun 2, 2014 08:56 AM
timmyboy76
Aug 27, 2011 12:21 PM
Deluxe06
26
Mar 2, 2011 04:38 PM
