Is this a CPS issue?
It is NOT the CPS. Though the Excursion started up and ran smoother in the driveway this morning, when my wife got to the same point on the road down from the house, the engine started stumbling again, though not as bad as before. Letting it idle for a few minutes, shutting it down, and restarting resolved the stumbling.
Strange thing is that once the truck has gone through this cycle once, there are no other symptoms at all.
Given the "cold" characteristics, I am wondering about the glow plugs or GPCM, but there is no white smoke at all on initial startup. I've also wondered about the fuel system as well, but once the truck has run for about five minutes there are no issues at all... again, this is true for both a nearly full or nearly empty tank.
Right now, here are my weekend plans:
1. pull the valve covers and see what I can find
. - put my $0.50 into the harness clips for good measure while I'm in there
. - check torque on the injectors
. - and possibly toss in a completely new set of GP's that I have sitting on the shelf.
2. pull the ICP plug because I'm seeing oil residue on the driveway and know that there is a slow loss from somewhere.
3. replace the fuel filter
4. do an oil change.
5. pull all four wheels to check the brakes out (unrelated, but necessary all the same to make sure I don't eat another rotor with a worn out brake pad somewhere).
I may just have to start some of this on Friday afternoon.
Any other ideas, guys?
referrelative="t">
</v:shapetype>.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" /><o
></o
>Taped up each wire then taped up the bundle then had a chunk of the plastic conduit type stuff that the rest of the wires are run through put that over the repair and taped the heck out of that problem solved for me!!!
Hope it's that easy for you!!! Good Luck!!<o
></o
I'm digging into the VC's regardless, and I do hope I find something to fix.
I've got the Ex back to the house easily enough because it was slightly downhill all the way home. Now that we're here, let me tell you what I've found thus far.
Oil level was way low... over a gallon and a half. I have oil in the valley, and I've know that I had a slowleak somewhere for quite a while, but didn't make the time to chase it down. Topped off the oil... NO difference at all.
What it's doing now is turning the engine over nicely (plenty of voltage), but after letting it spin the engine ofr about 10-15 seconds, it starts a high-speed chattering noise that does NOT sound like a starter noise... more like a relay chatter. This could be due to voltage drop from the load of spinning the engine that long. Regardless, the engine will not start at all... won't even try to start.
I checked the fuel bowl drain with the pump running after initial key-on, and it spits fuel greatly, so I know I have fuel pressure. I'll change the filter anyway because it's due.
I hooked up AE, and found a low injection pressure and low injection circuit code. I cleared the codes. Still no start, and the codes have not come back even though the engine will not start.
I am still planning to pull the VC's, but I am also beginning to wonder if this sounds like an ICP sensor. I tried unplugging the ICP, but that made no difference, and I did not see oil in the sensor.
So... in summary...
I have voltage.
I have fuel.
Repalced CPS twice with no improvement either time, and both CPS units were verified good running units.
I have no tell-tale codes showing up.
Any thoughts at all?
https://www.ford-trucks.com/forums/1...pr-sensor.html
