6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Sync Quirks
Old Nov 2, 2010 | 11:55 PM
aquaman's Avatar
aquaman
Sync Quirks
My Sync/Nav unit in my '10 has some quirks, namely:
- I get a bunch of 'P' POI's all show up at random even though I have all POI's tuned off
- There some confusion between the ambient light sensor and headlights. During sunrise, the display will blip between maximum brightness and the brightness I set it. Irritating
- It resets to maximum display brightness every time I restart the engine even though I set it to minimum brightness. It lights up the cabin at night and is blindingly bright, and I have manually turn the brightness back down all the time
- It sometimes sees "1 of 1" songs in my iPod even though it was working fine earlier.
- It sometimes get stuck 'initializing' while reading my iPod
- It sometimes powers up in 'Radio' mode even though I had it set to 'USB' input earlier
I have the latest v3.1 firmware. These appear to be software issues. Any of you guys see the same and/or get these fixed?
Old Nov 3, 2010 | 12:31 AM
fg250's Avatar
fg250
i can't answer to most of these because i don't have sync in mine... BUT the light sensor issue sounds the same as everyone elses @ dusk, dawn. The trip/odo display will flash back and forth between full bright and where you've got it set. What i do with mine is throw a glove or peice of paper or anything over the sensor to make it think it's still dark until it's bright enough outside to remove it and not be blinded by the light.
Old Nov 3, 2010 | 10:20 AM
RoadJunkie's Avatar
RoadJunkie
Isn't there a TSB on SYNC software update? Seems like I read that somewhere.
Old Nov 3, 2010 | 11:52 AM
Ricohman's Avatar
Ricohman
My ipod also gets stuck on one song sometimes. I have to unplug it and use it then plug it back in. I have yet to figure out if its the ipod or sync.
But the voice command will let you get around that problem.
Old Nov 3, 2010 | 11:55 AM
ChargersFanInCO's Avatar
ChargersFanInCO
Mine was doing that. It was the iPod.
Ted Bell
Oct 6, 2011 01:25 PM
srkr
6.7L Power Stroke Diesel
Jan 19, 2011 02:48 PM
aquaman
2009 - 2014 F150
Jan 6, 2011 11:41 AM
aquaman
Oct 28, 2009 02:33 AM
vfrrick
25
Mar 2, 2009 03:34 PM
