The title pretty well describes it. Noticed a few months back my speedo bouncing a little. It's grown progressively more pronounced along with my level of concern. To be clear I'm not referring to the tack or cps issues. Anyone know what could be causing this? With a magnetic pickup in the diff and an electronic cluster I don't have a clue where to start......and I don't want to start along side the road after something's died and I'm stranded. Thanks in advance!
VSS would be? Something to do with the speed sensor? Getting the impression this is a sign I've neglected the proper cleaning and feeding of a Sterling Axle.
I've had one wire in the harness up near the frame above the axle broke or pinched on my 96' powerstroker... also I've had a bad speedo with only 178,000 on it that was bouncing and causing shifting issues...
Pull the speed sensor on the rear axle and clean it. But while it's out.....here's the kicker. Have the rear end up on jack stands and have someone slowly spin the wheels while you look at the tone ring with a flashlight. Make sure there are no teeth missing or chunks gone. If there is.....there's only on thing that causes that and that's broken differential parts. So if the tone ring is okay, reinstall the clean sensor and breath a sigh of relief. Then start looking up the line if the speedo still jumps.
