i have a 91 ford f250 5 speed and the check engine light stays on so i ran the ecc test and it came out as 998 126 118 i have no idea where to start looking for the problem the codes read
engine control system running in failure mode for 998
map preasure sensor voltage to high for 126
engine coolant sensor voltage to high for 118
i am really hoping to not replace the ecc if thats what is wrong someone please help explain whats wrong
Check all your grounds. There are several of them and check all leads going into the computer. I had a bronco once that was spitting all kinds of codes, and I found an inline fuse to the ECU blown, and corroded grounds.
