I just ordered a set of Mile Marker hubs but I noticed the spring clip used for installation is different than the Ford factory clip. The Mile Maker spring clip looks like it will be hard to remove later when I want to pull the hub to service the needle bearings. Has anyone removed these after install? Any tips or tricks to removing the spring clip?
Thanks, Jasonodsky
I am going to put these on this weekend and I was wondering if you bought the conversion kit part # 95-32721 for it.
Thanks Tony
I am going to put these on these Mile Marker hubs (449ss) on this weekend and I was wondering if anyone on here bought the conversion kit part # 95-32721 for it.
The instructions says SOME newer fords 1993 and up require
(keyword SOME you would think they would know which ones.)
