Head questions ?
Old Nov 1, 2010 | 05:54 PM
ah1988's Avatar
ah1988
Head questions ?
How do you tell if there is a leak in the head gasket, i was looking at the A/C compressor that the shop did not put a clutch on ,what dumb F#%*'s
do that then send you down the road whithout telling you, they forgot to put it back on what a lame excuse ! Any way i found like a oily dirty sandy grit layer around the heads where they bolt down into the block where the gasket would be. Are they leaking or am i just being a freak ?
Has anyone heard from oreo havent heard from him in a while ?
Old Nov 1, 2010 | 06:01 PM
rodneywar's Avatar
rodneywar
oreo is busy with his truck putting some ladderbars in and changing the gears out last time i heard
Old Nov 1, 2010 | 07:31 PM
tjc transport's Avatar
tjc transport
i ain't rite
if the truck runs good, i would say you are being paranoid over nothing.
my 88 has the same thing. it is oil residue that stuck there from the weeping valve cover gaskets that picked up road crud.
it has over 300,000 miles on it, and has not been washed in over 15 years. the dirt and crud are what is keeping the oil in the engine.
Old Nov 1, 2010 | 11:51 PM
polarismuddman's Avatar
polarismuddman
I agree with TJC......where are you at in Florida?
Old Nov 2, 2010 | 11:36 AM
ah1988's Avatar
ah1988
I live in central fl too!
Deltona area
Old Nov 2, 2010 | 08:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Most of the time the only head gasket leaks you need to worry about either let coolant into the oil and/or compression into the cooling system.
Old Nov 3, 2010 | 03:04 AM
polarismuddman
I'm over in Lake county...we're practically neighbors...
